Radios that are water resistant with speaker mic
ccw
Carpet Delete Missionary
Founding Member 📜
Retired Mod ⚒️
Washington
2022 F-350 Tremor 7.3L
1980 Mazda RX-7
Ok, I know there's some fellow radio nerds on the forums. I'm looking for water resistant handheld/portable radios that retain their water resistance with a speaker mic attached.
Specifically, I'm looking for both Ham and GMRS radios that fit that.
On the GMRS side, the only option I found is the Baofeng UV-9G. Biggest issue with it is I don't now how comfortably I could hand it off to a non-radio person and have them use it. It appears to be very much a ham radio locked down for GMRS. But not a horrible option.
On the Ham side, I currently have a Yaesu VX-6R that fits that bill. It's fine. But I hate a bunch of the ham radio "convenience" features (e.g. automatic repeater offset), and the interface in general is a PITA since they crammed so much into it. I want to get setup with two handhelds so I can work two channels at the same time, and all else fails I'll get a second VX-6R, but I keep hoping there's something better out there and I can sell off my VX-6R.
I'm also aware of the Icom IC-T10. I love that the chassis is the same as the Icom F1000/2000 land mobile radio. I hate that the screen is ancient (e.g. can't display all the capital letters) and that it doesn't have memory banks. The number of channels is fine (not ideal), but not being able to organize them isn't great. It's a shame they didn't take all of the features from the F1000/2000.
The Icom ID-52a looks great, but it's so bloody expensive. And a ton of that expense is going into features I'll never use (digital, waterfall display, etc).
My dream radio is a dual-band land mobile radio, but assuming I stay out of the bargain basement, the starting price for a dual-band land mobile is somewhere around $4000-6000. Not exactly affordable or reasonable.
<rant>It's insane the number of non-land mobile radios that advertise water/dust resistance, but quietly disclose in the manual that the water/dust resistance goes away when you attach a speaker mic. It's never disclosed prominently. This is nearly all non-land mobile radios as far as I can tell.</rant>
I'll check my dual band (VHF/GMRS) but it probably falls into the disclaimer category :unsure:
I hate to say it, whatever you find will not be cheap.
  • Sad
Reactions: ccw
I have a couple of the Baofeng UV-9G with the hand mics. Use them when I'm out in the SxS. I washed them the other day after a 3 day trip and they still work fine. Don't need to know how to do anything special to use them. I just set them up and then lock the keypad so whoever I'm with can't accidentally change channels. As long as the other person can figure out how to push the PTT button they can use it.
I know. :cry:
Good to know! Thanks for the feedback on it!
@ccw here are some pics of my Cobra VHF/GMRS handheld. It may not be the radio you need from a frequency perspective, but possibly you could look for the same type of external interface feature.
This radio has a IPX7 waterproof rating and there are no disclaimers in the supplied documentation regarding reduced capability when the speaker/mic interface is in use. Looking at it from a water ingestion standpoint that makes sense as the sealing mechanism doesn't change. It uses a threaded barrel with a rubber washer which replaces the cap when using the built in speaker/mic on the radio.
Hope that helps... :)
Edit: Here is a link to the model I have:
Well crap. That's exactly what I'm looking for on the GMRS side! But it's discontinued. And it appears the supply chain has run dry (all sites I can find are reporting out of stock).
All the newer models have dropped GMRS and are marine VHF only.
(For reference, that's the Cobra MR HH450: https://www.cobra.com/products/mrhh450dual)
Here's a pair, but they're used:
One Ebay seller has some leftover stock of the HH450 in camo:
Of course they have to be camo. I feel like that would look so cheesy when working an event.
Nothing is ever easy, is it?
Have you looked at the Wouxun KG-905G?
Agree... I've been keeping my eye out for another so I could have a pair but all I've seen are camo. There is another on eBay that is black but non functional for $40. Hmm... That gives me an idea...
I have. Admittedly that one doesn't state it loses water resistance with a speaker mic attached, but there's also nothing about the speaker mic that leads me to believe it retains its water resistance. If someone can show there's an o-ring or gasket involved in the speaker mic connection, then I'm very interested.
Ohhh that is a good idea! Buy a camo one and the parts one, then make a functional black one out of both!
