Earlier this week, I had a set of tires and wheels mounted and balanced. The shop used silver wheel weights, but the wheels are black, and my OCD won't allow that. I have purchased black weights to replace them. While they are the same weight, they are different in size (a bit longer). For those with more automotive knowledge that me, my questions are:
- If there are 5 x 1/2 oz. weights mounted now, if I find the center of those, mark the wheel and then find the center of the new weights and attached them on the mark I made, would that work?
- If the above is true, if there are 6 x 1/2 oz weights mounted now, can I replace those with 3 x 1 oz weights, following the same process as in my first question?
I'm not entire sure if the weight needs to be spaced over a certain distance on the wheel or if the center point is really what matters.
Worst case, I can take the wheels back to the shop that mounted and balanced them and ask them to use the black weights, but I was hoping to avoid doing that if I can.
Hopefully that makes sense.
Thank in advance.
Thank in advance.
