Question about PMF rear leveling blocks
own1bigtruck
New York
Army Retired
First Responder
Firefighter
2026 F-350 Platinum 6.7 HO, "Betty" (White)
I am about to purchase an F-350 tremor (most likely going to end up being a 2027 order). I test drove a 2026 and it will clear my garage door, but just barely. Living in upstate NY where snow is a real thing 8 months of the year, I am afraid that any snow pack in front of the garage door might prevent the truck from clearing. My question is for those that have installed the 2" or 1 1/2" Reverse leveling blocks on their tremor's, how much does it lower the rear of the cab where the dang antenna blocks are located? That is the tightest fit clearing my garage door with only about a 1/4 inch to spare (the seal is dragging over them). I would go with a non-tremor, but I really want the front axle only available in the tremor.
I just installed the 2" blocks and my rear end came down about an inch and I still have a pretty noticable rake front to back. If I did it over again I would definately have used the 1.5" blocks.
I think the 1.5" even has a slight rake but it will still lower your truck substantially. I dont know the exact math on how much lower that specific part of the cab gets but it will absolutely give you some additional clearance. I think 1.5" is the way to go.
I run 1" rear blocks and lifted the front a little which gave me a level stance on a 22, however my situation is different because i have air bags aired up to like 15 psi unloaded that make up for some of the additional drop of the 1" block.
