Problem adding to existing order
Reefertech
Founding Member 📜
Plant City, Fl.
2022 F250 Tremor Antimatter Blue BAP
I was informed today by my dealership that when Ford stopped taking new orders on 4/1 (which I knew) that they also shut down being able to make changes to existing orders (said entire page for doing this was gone). I read on blue oval forum that you can still make changes after 4/1 to existing orders except for body and pep codes. I did a search as to what PEP codes are and it shows that is trim level so things like 5th wheel, upfitter switched and marker lights should still be able to be added from what I am reading.
Has anyone else had this issue and am I understanding what I have been able to find out?
What i heard time and time again is that changes to orders, in many cases the unscheduled ones, was one of the main reasons Ford has had such a hard time scheduling. I never believed that was the only or even the primary reason, but i am happy that they locked it down completely now. Hopefully all of the unscheduled folks will start receiving build dates with this lock down.
I decided to add power running boards a couple of days ago, my dealer had no problem adding them.
They took the SD off of the CONCEPS system, the dealer can still make changes through the WBDO system.
i'll believe it when i see it
I successfully had my dealer do a color change yesterday. However, I did not add any new components.
The only one it affects by me making a change to my order is myself, it would have no bearing whatsoever on someone else's order.
