Anyone else having issues setting up trailers for Pro Trailer Backup with the stickers after FORScan mods?
I did a bunch of FORScan mods as soon as I got my truck. I didn’t get the fifth wheel prep package from the factory so I spent some time buying and installing a gooseneck hitch, a yaw sensor, and the in bed 7/12 wiring harness. Finally got that all in and got a gooseneck trailer setup with the yaw sensor with no issues.
I then tried to setup a bumper pull trailer with the sticker. When I go into the trailer menu and start the Pro Trailer Backup setup the screen immediately starts flashing back and forth between the normal sync menu and a CGI picture of the sticker. Above the sticker a message says ”Place sticker now” but it never finds the sticker on my trailer. The screen is flashing back and forth about every second and none of the buttons no longer work. I have to turn the truck off the get out of the Pro Trailer Backup setup.
I took the truck into the dealer once and they were too lazy to even look at it. Just gave it back and said since it worked with your gooseneck it must be a wiring problem with your bumper pull trailer. I’ve tried multiple trailers now and there is no difference.
I made an appointment to take it back to the dealer, but had a random idea after reading about the KIP problems with nav in motion in the full screen CarPlay thread.
I used FORScan to restore all the factory settings and tried to setup a trailer. Everything worked fine with no issues.
I restored my Forscan mods but turned off nav in motion and it’s back to the flashing screen when I try to setup a trailer.
Obviously, a FORScan mod is messing it up but I have no idea which one.
Anyone have any ideas which module might have anything to do with Pro Trailer Backup to at least maybe narrow down which settings to look at?
