Pro-Power Onboard 2kW Question
what's your setup? you running a/c off batteries and the ProPower is charging the batteries? I tried to use mine to power my trailer but the trailer didn't like the open ground and it wouldn't work. Best I can do is use the bluetti with the bonding plug and have the truck charge the bluetti
I installed lithium batteries and a Victron system with solar and inverter/charger. The solar charges the batteries and the ProPower also charges via the inverter/charger just as if plugged into shore power or generator. To address the open ground issue I installed an EMS and to make connections automatically switch between the factory shore inlet and the one I installed at the front of the camper I installed an automatic transfer switch. I can provide a bit more info if you need just DM me.
