Possible to get power from the in bed 5th wheel plug?
Two things. First, as a fellow Willys owner I feel like I have to ask what model you have.
Second, running a small 14ga wire from the battery back shouldn't be that hard at all. If I were in your shoes, id connect the wire to upfitter 5 or 6 and flip the little fuse in the junction box. That way you can turn off the socket when you want but with the fuse moved it'll stay on with the key off.
Question... if you use an up fitter switch and run a wire back do yo need to disconnect the original wire or can you just add the additional wire from the up fitter switch.?
If I'm understanding the question correctly, there are blunt cut wires with protective caps on them under the hood on the passenger side. You'll need to butt connect, with heat shrink, to one of the wires on the pigtail. From there you'll run to the back of the truck. The actual switches can't and don't handle any actual load. The relay bank in the engine bay handles the loads and the pigtail harness is their output.
5 and 6 are the only two that can be set to run when the ignition is off. You'll want to use one of these two if you want cooling while parked. Also, 5 and 6 are the only two rated at 40 amps versus the 20 (or 25, can't remember) amps of 1-4. Obligatory, watch your battery levels. Jumping is never fun.
There's a little 5 amp fuse in the relay box that needs to be moved to allow power while ignition is off. Let me know if you have any other questions.
All correct just wondering if I run a wire from there ( wire harness) to the rear "plug" do I need to disconnect the original wire so it won't cause an issue with the other system
(I have my ARB compressor on with 6 and made it hot )
My reason is for my enclosed motor cycle or in winter snowmobile trailer. All my other trucks ( Dodge & GM) were hot. so at night when I went to the trailer ( with engine off) I could flip a switch ( inside the trailer ) to turn inside trailer lights on, and check my bikes. Seems impossible to just flip a simple switch with the Tremor. I could deal with using an up fitter switch( #5) but don't want to cause issues with the system or don't want to disconnect the main line to the 5er plug
1951 M-38.
I have a oversize wire running to my ham radio behind the back seat on the passenger side, think I might just tap into that and add a socket in the bed like some others have done. Wire is already most of the way there, seems like it might be the easiest way to go.
@PapaRaptor
You have a couple possible options here. The plug in the bed (and the bumper) are connected together and fused in the engine bay. IF you wanted to make your 40amp upfitter switch over ride the factory 12v supply you could just run a wire from the blunt cut wire harness into the fuse box. You'd have to find the fuse for the 7 pin 12V constant and connect the wire to the fuse leg going back to the plugs. This would make both 7 pins switched with the upfitter.
If, however, you'd like one of the two plugs to be upfitter and the other normal then you'd have to run the new wire to the plug you'd like switched and disconnect the factory 12v supply from within the receptacle.
A third option, if you want both worlds, would be to use diodes and the fuse block connection from the first option. This is a bit more complicated but you'd have normal 12V when the upfitter is off and always on when the switch is on. The dual feed situation becomes a non issue with the diodes.
1951 M-38.
What a beauty!
I've got a 61 CJ. Did a full chassis off restoration during Covid.
