Planning out my 30 gallon in-bed auxiliary fuel tank for my 7.3L Tremor
I was looking at doing something like this. While a hassle to get out and fill up the truck, it would eliminate any possible warranty issues and them being denied.
This option crossed my mind again after recently seeing this video:
Having an entire tank refill on hand (and then some) would be great, but its the loss of bed space that has me on the fence.
I have the revised mounts for two Wavian Jerry cans almost complete. This will provide 10-11 gallons and will I live with that solution for awhile before dropping any additional considerable money...
Where do you cross the weight line having so much gasoline onboard you actually reduce your mpg and it’s defeating the range extended?
My concern is while towing our TT and I'll only be getting ~8mpg anyway so I don't think another 400lb or so will outweigh the benefit of having it.
I should be able to get some pictures this week before I paint the brackets showing my 10gallon setup. They will be mounted to the rear Builtrights and I'm hoping I can get a fire extinguisher on too... Stay tuned.
ATI makes an aluminum auxiliary 30 gallon gasoline tank that I would like to put in the front of the bed of my F250 7.3L Tremor.
Before you give me crap on selecting the smallest 30 gallon auxiliary tank option, this tank size fits perfectly under my Bak Box Toolbox and Backflip folding bed cover, and also takes up the least amount of room in the front of the pickup box as well. Plus, 64 gallons of gas (stock + auxiliary) gets us the maximum distance our kids will travel towing our travel trailer in one day anyway (~ 500 miles or 7 hours on the highway).
Need some help verifying / planning out a few items regarding the installation.
1. Is the 7.3 factory fill line a standard 1 inch inside diameter for the optional 1 inch fill neck adapter to fit correctly ?
2. What is the inside diameter of the 7.3 factory tank vent line so I can purchase the proper “T“ adapter to plumb the auxiliary tank vent into the factory tank vent line and close the ventilation loop to ensure I don't get a check engine / loose gas cap indication on the dash ?
3. Any recommendations on a similar yet quieter in-line fuel pump than the Airtex E84070 recommended by the tank manufacturer ?
You able to put a truck camper with that installed??
DA
Given the energy density of gasoline or diesel I doubt that threshold, where your range starts going down as a result of fuel weight carried, is anything feasible for the truck to carry. I actually wonder if it's possible to cross that threshold at all.
It certainly becomes impractical and/or not economical at some point, but wouldn't reduce mpg to the point that your range starts going down.
Looked at that one before buying a 58 gallon portable tank. It doesn’t fit under the tonneau but can easily take it out if wanting full use all of my box. I eventually will wire a Anderson plug on one of the last 2 upfiters to run the pump. It’s so convenient refilling toys and truck bought a similar one for diesel for the tractor. Had to remove the cover roll to ensure there is enough room to still be able to use the gooseneck hitch.
Was talking to a rancher that had a 130 gallon (I think that’s what he said) diesel tank in the bed of his Chevy truck at the commissary. He said he hated driving it when the tank was full of diesel it got such crappy mileage so he drove it in to fill and then it sat till the diesel tank needed filling
But then again diesel is heavier than gas and this was on a older flatbed Chevy
Just have to much empty space between my ears thinking about the new 58 gallon tank and then a secondary tank in the bed
Our upcoming trip to Canada has me looking at distance between towns coupled with gas prices and if the 58 gal tank would be a option as gas in Canada is $1.59 to $1.87 a liter
Oh ya that much weight would make the MPG terrible, hence the economics of it potentially becoming not worth it.
But I bet despite the bad fuel economy if he added another 10 gallons his range would still go up. Sure that 10 gallons wouldn't go as far as if the truck were lighter, but it's not like adding 10 gallons (whatever that weighs) would make the range go down. It wouldn't even be close to that point.
@Gus I finished the mount revision and will be installing these this weekend onto the Builtright panels. They started off tall with the metal strap over the top (see pic below). I didn't like that for a few reasons. 1) the rivets dug into the top of the tank when secured 2) it was extremely difficult to remove/replace the can with the rails for my tonneau (Sentry CT). I modified the mount so that the strap secures around the front. I added some weatherstripping on the metal strap and it can be really cranked down now without damaging the can itself. All touch points have protection so there is no metal to metal contact. I'm thinking about adding the two red rubber straps over the top as backup but once installed the can will have no place to go. It is trapped vertically between the mount and cover rail. I'll post more pics once they are in the truck:
Was looking back a old receipts and I have noticed with my 58 gallon tank there’s nominal effect with it in when hauling my 25’ enclosed toy trailer. Still getting right at about 8 going to the sand dunes and within about a tenth of a mpg from what I was getting the year before adding the tank. Loaded trailer weight is around 8500 lbs with same toy load. With this trailer have found empty vs loaded has minimal effect on mpg. 205C1914-3A6D-4917-9634-CC6B127094AF.webp
Jumping from that 8500 lb trailer to a 14Klb trailer only cost me less than 1.4 MPG and that was with a nasty head wind. Did have the transfer tank out due to concerns with GVWR constraints but would have been OK with it after weighing.
If towing adding extra fuel should have minimal effect on MPG and could have more effect when empty but with 58 gallons didn’t really notice a big mileage hit this summer since had the tank in the entire summer.
Was looking back a old receipts and I have noticed with my 58 gallon tank there’s nominal effect with it in when hauling my 25’ enclosed toy trailer. Still getting right at about 8 going to the sand dunes and within about a tenth of a mpg from what I was getting the year before adding the tank. Loaded trailer weight is around 8500 lbs with same toy load. With this trailer have found empty vs loaded has minimal effect on mpg. View attachment 105256
Om surprised with your mileage. I've got a non tremor 7.3 with 3.73 gears. I get 10.5 towing either my 32' 5th wheel or my 7x25' 7' door opening enclosed trailer. This is hand calculated and I have 30k miles on my truck
We used .1 MPG on average for every 100lbs vehicle weight as a starting point when I was still working. Now that depends on alot... Like what curb the vehicle starts with before adding the weight, specific powertrain, etc. Towing complicates things since you have the direct tongue weight plus the drag of the trailer (weight and aero).
Since a SD is a heavy pig even unloaded I would start with .1 for every 150lbs. Using my own example if I get 15MPG on the highway and reduce by 5.5 just for the weight of pulling an 8k trailer it puts me under 9.5MPG. Aero accounts for the rest depending how fast I'm traveling, headwind, etc. I will also add that the degradation tends to diminish as the weight increases after a certain point, unlike the aero which keeps exponentially increasing with speed.
Not an exact science because of all the variables.
For the weight of 30 extra gallons that would be ~.15MPG also accounting for some extra container/tank weight.
@2020Tremor your trailer example illustrates my last point above and is definitely interesting. You are already taking the aero hit with the lighter trailer so instead of 3-3.5MPG due to the load from weight, it is less than half of that. Like I said, definitely where a rule of thumb is not a one size fits all approximation!!
Wow, that's great! I don't see anywhere near that with my 32' TT but I have a 7.3 Tremor. Your gearing, tires, and air deflector are showing their benefit here!!
I can attest to the aero effect on the cargo the roof top AC cost about 2mpg after installing it on my previous rig. I actually got better mileage pulling my buddies 27’ camper than my cargo which had a flat nose and weighed about the same, really don’t think the V is helping as much as everyone said it would.
Hers a better conceptual visual of the point I was trying to get across. For a 7.3 a fuel economy curve would look something like this:
Here is one of the tanks mounted in the bed:
It is almost hitting the wheel well but there is a bit of clearance. That is how the existing holes lined up on the rack so I am calling that good!
I have just enough room to tilt the can and easily remove or replace it in the rack and under the tonneau rail:
Bumping this thread again to see if anyone here ended up installing one of the ATI tanks? I am back to thinking of adding one of these tanks possibly even as large as the 46 gal tank, which would give me 80 gals overall, ~640 miles when towing.
To get around the concern of overfilling the tank I would put the pump on a timer. After turning the pump on it would only run for 10 minutes or so until you turn it off and on again (or possibly push a momentary switch, having completely finalized that plan).
I was able to find online that a few other people have done this with gas vehicles and have not had issues. Seems more people have done the transfer tank style, rather then directed plumbed aux tank, which uses a standard pump handle. But I like the idea of not having to stop to fill up. Still need to stop for food and bathroom often (slowly conditioning wife and daughter to longer driving legs) but just pulling into a rest area or large parking lot for just that would be super nice on the long camping trips.
I've spent the better part of a year now with toolboxes stored in the front of my bed. Haven't missed the space to be honest. That's good news for putting in a tank, but then where would I put the boxes or all crap that's in the boxes? I probably don't need all of it all the time, it has been more of an experiment...
I haven't had nearly as much stuff as you but haven't needed my whole bed so not as worried about losing the space as before.
You could always move your boxes out if you need the space on the rare occasion.
I also question if you could put them on top of the 30 gal tank. But I do think the the 43 gal tank might be the one I get. I want 46 gal but the filler neck appears to be in the middle vs the 43 being near the edge.
The other thing I've realized is that for a manual transfer process you need to ensure sufficient throughput so you're not standing there all day. Some are like ~1 gal/min which isn't going to cut it imo. One of the auto fill (manually triggered) was the same but ideally that could be used while driving as you stated @MiTremor906 ... I still haven't looked into it that is legal, though, with a gas truck, or if the setup would end up generating a CEL for EVAP (similar to if the gas cap was not seated). I like that concept the best though!
For my 10 gallon setup I bought a mega siphon and man that transfers quickly! It will go through each can in about a minute:
