B
BlueKilla
Guest
He knows absolutely everything and if you aren’t in 100% agreement with him you are wrong, no questions asked!
I'd like to petition the mods to add a permenant Shrike9 tag under his user name.
Yeah, TJ Carr
He blocked me when I called him out.
You strike me as someone who can appreciate a quality holster. https://bullardleather.com/collections/iwb-holster This is the best holster that I have ever had and I have had lots.Bad day & not in good place, cold weather makes the body screaming no excuse, I’m not socially acceptable
anywhoo, look at it, where is it pointing, you are violating 1 of the 4 cardinal rules of gun safety, it’s pointed at your leg/foot depending on how you move, you never ever point a gun at your body pieces parts
When you carry a gun, keep it on your body unless you can not, then lock it up, a good quality holster/belt will make it so it does not hurt, it should not be “comfortable” but a firearm is “comforting” and you should always feel where it is on your person, but lots of cheap holsters and/or belts will make hot spots, make it yet, be annoying and thus you remove it to be comfortable
Access, it is slower to grab it if you need it, this is a training issue, you can stage your firearm around the seatbelt if you are in downtown Mogadishu & expecting a gunfight
Administration gun handling, the more you play with your gun, the higher the risks of it going bang when you do not want it to go bang, holstering a firearm can cause your body to twist/turn/contort in such a way the muzzle points at your body & if a piece of clothing or something gets inbetween the holster and trigger…..bang
How do you sadly holster it or draw it & place it in that holster without anybody seeing it, do you hope nobody sees you in the truck, stand up behind the open door & hope nobody sees you?
In some jurisdictions it is illegal, if you are on a road trip, or Travelling across state/city lines, need to make sure it is legal
In a crash, it can become yet another flying object and that’s never good
It’s easy to forget when you stop for gas, to take a emergency dump, grab a burger, anything that causes you to get out of the truck, so yo are unarmed & then your truck gets broken into and you just armed a thug
If something bad happens and shit goes sideways, you panic and freak out, the gun gets forgotten, some thug grabs at you, the gun is not where it’s needed and you fumble & do not gra it, now thug has another gun
Not all holsters are created equal, some are cheap copies of more expensive holsters & some are just garbage & uncomfortable/hurt and do not conceal worth a crap, pick a holster for what you are doing, you might have several holsters or the same gun. Don’t cheap out on a holster, why put a $600 gun in a $35 gun store holster special that’s cheap and a huge profit margin, skip the flashy marketing and do research, buy quality
Belts, not all belts are designed to hold up a gun and extra ammo, it needs to be sturdy, but not stupid stiff and contoured to your body, agsin not a cheap belt, they are a very important part of the concealment system
Show me a holster that never points at any part of the body. Bottom line is discipline, training, and practice are what's most important. Some of your replies make me think you are someone that angers easily and should not possess any weapon.
It was pure coincidence that you appeared immediately after his ban and also share the same profile location and post "quality". I could be wrong, but I am pretty sure I'm not.I am not this Shrike you speak of and I have not blocked you, please stop lying
I really feel sorry for you, seems all you do is make false accusations and assumptions about me, I forgive you for being such a negative person & not having anything positive to bring to the discussion & instead exist to troll me
Also happens to claim to be an ex-firefighter, ex-military, ex-Kalif, with similarly piddling knowledge about each subject.
That is a nice setup!I had someone ask me what pistol mount I went with, so I thought I’d share. It’s a DARA mounter holster.
View attachment 39503View attachment 39504
This is the mount I use. Your can also get 3M backing from the company which is a PITA to remove. https://vulcanarms.com/products/vulcan-quickdrawI had someone ask me what pistol mount I went with, so I thought I’d share. It’s a DARA mounter holster.
That’s nice that you can carry it unloaded and quickly rack the slide after you have established a good grip. Thanks for sharing!This is the mount I use. Your can also get 3M backing which is a PITA to remove. https://vulcanarms.com/products/vulcan-quickdraw
A empty pistol is worthless, but you can rack it fast, really fast. Take my word on that.That’s nice that you can carry it unloaded and quickly rack the slide after you have established a good grip. Thanks for sharing!
Thanks for the post. I hadn't read the actual verbiage of the September 2021 changes.Now that constitutional carry is in effect, this is definitely no longer an issue. The only restriction for open carry would be that the firearm must remain holstered..which this solution checks the box for. The change in the law this year specifically removed the definition of a holster to mean a belt or shoulder holster..which was a gray area before on what qualified.
reference: https://capitol.texas.gov/BillLookup/History.aspx?LegSess=87R&Bill=HB1407
Code:BE IT ENACTED BY THE LEGISLATURE OF THE STATE OF TEXAS: SECTIONA1.AASection 46.035(a), Penal Code, is amended to read as follows: (a)AAA license holder commits an offense if the license holder carries a handgun on or about the license holder’s person under the authority of Subchapter H, Chapter 411, Government Code, and intentionally displays the handgun in plain view of another person in a public place.AAIt is an exception to the application of this subsection that the handgun was partially or wholly visible but was: (1)AAcarried in a shoulder or belt holster by the license holder; or (2)AAin a holster, and the handgun and the license holder were in a motor vehicle.
edit: removed prior comment about the law prior to constitutional carry since the definition of a holster was not well defined and it could be debated as to whether this solution would have qualified or not.
You mean like this: (fast foreword to 26 seconds) All it takes is a good professional trainer who knows and understands what he/she is teaching, it’s actually quite easy to engage a mutt from inside a vehicle with a firearm holstered on your person if you have proper training.
