I'm using the Peak Design powered mount (actually, two of them, one for the passenger too). Not cheap ($80), and you have to get matching cases for your phones ($30-40). The cases are very nice (have had them for about 18 months now, and they are still in perfect condition, very impressed with quality. The magnetic hold on the mounts is perfect. Much more secure than magnetic mounts I've used before. Does not move when off-roading, although I'm not doing any rock crawling or anything. I used some 90º angle USB-C adapters to make the cable runs as clean and direct as possible. One on the base of the driver's charger, and one on the plug end of the passenger one.
this is the best location for me - I don't like them up high on the dash, and the way this is setup, the only thing that's obstructed from driver's view is the driver's side temp dial... which I can easily just reach around and spin without seeing it (and temp shows up on screen anyway). A minor inconvenience, and I've been happy with it for 18 months. Nice to just drop your phones on and they start charging.
I have the same mount and agree - it's awesome. BTW, at least with an iPhone, you don't need a Peak Design case - just any case that is Magsafe compatible. I have an Otterbox case on mine that I picked up for about $30 on Amazon, and it works perfectly with the PD mount.
