Option questions about Ultimate Trailer, Winch, etc
My Tremor does have 2 batteries so I thought I should be fine. I just traded my 07 Power Wagon, one battery but was not sure what amp alternator it had but never had any issues running the winch. I’ll go ahead and order the winch. Gonna install myself. Should be pretty straightforward. Good videos out there.
Well dang, I'm gonna have to install that yaw sensor and give it a try now. I just assumed it lets you turn the knob instead of the steering wheel. That sounds pretty cool.
If you’re using a bumper pull, search and read up about the yaw sensor on those. It’s not straight forward. You can use the black/white checkered stickers which you should have been given for setting up a bumper pull trailer.
@idrivea2022tremor was referring to an isolated battery setup. The factory dual batteries are wired directly in parallel, with no isolation. They act as one large battery at all times.
That does still help with the winch as it gives you more capacity for the winch to draw on, though that will take correspondingly more time to fully recharge of course. But if one battery is drawn down, the other one is as well by definition.
If it were me in your shoes I would at least do a second battery and have the winch run off that. Use a disconnect to keep the main and aux battery separated so long draws don't interfere with the truck's electrical system. Look into the SurePower 1314 disconnect, it's an Eaton product.
Question about this. I looked up that disconnect and it has a 100A rating.
Will it limit the current draw to 100A? Or will it blow up if something tries to draw more than that?
I ask because the winch could exceed four times that current. And if the relay in the disconnect is closed, I would the main batteries would try to “recharge” the winch battery with the same current? That could be wrong; I’m not confident in that statement, and is why I’m asking.
Even if we conceptualize the winch as pulling from all the batteries when the relay is closed, as they’re hooked in parallel, you would still be pulling at least double the winch’s current through the disconnect unless it dynamically limits it.
To avoid this problem (if I’m right; if I’m wrong ignore this :)), you would need a DC-DC charger, not a disconnect, and have that DC charger only on when the vehicle is on.
From the specs the 100A is continuous load:
Continuous Relay current
IR,MAXC 100 A
Inrush Relay current
IR,MAXI 400 A
30 seconds on, 6 minutes off duty cycle.
There is also a 200A version of this product... (1314-200) which has 200A continuous and 600A max at the same duty cycle.
  • Like
Reactions: ccw
I would "assume" most large dealerships have installed a few winches by now. That wasn't the case in 2020/2021. If it were me, I'd let the dealer install it. My winch has failed twice, each time they noted corrosion as the problem. My last visit, they replaced the entire winch under warranty. Had I installed it, I'm not sure corrosion would have been warrantied.
A couple of questions for those wiser and more experienced than me:
1) Winch. I can order the OEM Ford Performance kit from local dealer for $800 less, and get the peace of mind of installing it myself (had bad experiences with dealer-installed options). Seems like a win-win. Any reason to have them do it?
2) Ultimate trailer tow package. Is this worth it? I don't think I'll ever use the little cheater knob on the dash, but the 360 camera and ability to have a trailer-mounted camera tied in to the factory reverse camera system seems cool. Would I have to use the specific Ford OEM camera or would it be able to work with some aftermarket setups? Similarly, can I get multiple cameras and mount on multiple trailers?
Thanks for the guidance
If you have adaptive cruise, it can be a pain in the ass to get it to play nice with the winch ACC bracket - it also uses specialty fasteners that you will not have on hand. I had the dealership do it so that it would be their headache, not mine.
The pro-trailer backup system is a complete gimmick in my opinion. I spent the 30 minutes to set it up, tried it for 10 seconds, didn't like it and said forget it.
IR,MAXC 100 A
IR,MAXI 400 A
Good to know, and thanks for looking it up.
To me that’s not a great duty cycle. I know you’re supposed to let the winch rest…but resting for 6 minutes after just 30 seconds of pulling? That will make for some ridiculously long pulls and I believe is significantly more resting than is called for by winch manufacturers.
I’m happy with the factory dual batteries for the winch, and would be even with the 200A alternator. But YMMV. :)
