Opened door this morning after a night of heavy rain and water poured out of the rubber weatherstripping.
Birdhunter39
Md
First Responder
To the dinner bell
'22 7.3 Stone Grey
I mean like poured. Not just dripped. Didn't see anything come out of the weep holes in the aluminum. Seemed to pour from the bottom of the door panel behind the weatherstripping/seal rubber thing that runs all around the door.
Is this normal?
I have not seen this. Which door? I assume drivers front? Are you parking on a level or incline area?
Drivers.
Slight incline such that rear tires are a touch lower than front.
I've noticed the drivers door doesn't close quite flush to the rear door. No noticeable wind noice from this though.
Is this normal?
My 2017 had this issue. Water gets in the door. It’s normal on every vehicle. The water runs down the window into the door an should get deflected and come out the weep holes. Sometimes the weep holes are clogged up grease or debris and the water backs up. Or the water is getting deflected onto the clear plastic behind the door panel and leaking past the butyl seal and it comes out the door panel
Try running a small piece of wire up
The weep holes to clear anything that maybe plugging them.
Mine has done it several times from each front door. The water gets trapped around the door gasket. Not the gasket thats passes threw the threshold. It's on the ever increasing " needs to be looked at " list.
Yup. Happened on my 16 F150 and has been a problem my wifes last 2 Ecosports as well. Poor design on the door gasket on many models.
During the winter months when it got to about 20 degrees here my drivers door would not unlock with the fob. I'm assuming water is getting in my drivers door. Dealership stated they could not look at it unless it was happening at the time. By the time I drive up there it is unthawed and works fine. We didn't get many nights around that temp. At the time there is no bulletin for these trucks.
