Onboard Air (OBA) options/parts list
NomadTremor
Tremor Fan
Colorado
USMN
2018 F150 Platinum
Good evening!
I would like to install OBA on my truck. I would like to use it for tools, Tires, winterizing RV, bags etc…. I am not quite sure how I am able to use the tank and compressor to fill the bags to the desired PSI. I have found fixed pressure switches, but not a variable pressure switch. I would also have to adjust the pressure to winterize the RV and may have to depending on the tool that is used. Thoughts?
So far my suggested parts list is:
Vixen Air 5 Gallon (18 Liter) 9 Ports Suspension/Air Ride/Bag/Train Horn Air Tank 200 PSI (Silver) VXT5200G https://www.amazon.com/dp/B07G6MCG4...abc_310SHV0P9DXJY17TXDM1?_encoding=UTF8&psc=1
ARB CKMTA12 ARB505 On-Board Twin High Performance 12 Volt Air Compressor and E-Z Deflator Bundle https://www.amazon.com/dp/B07HP9NW9...abc_PSZ2MN40BA1WC4K99H71?_encoding=UTF8&psc=1
Daystar, Air Bag Cradle designed for full suspension travel, Fits All 6" diameter convoluted Air Bags, fits any full size of half ton truck, 2/4WD, KU09140BK, Made in America , Black https://www.amazon.com/dp/B0084ROJBM/ref=cm_sw_r_cp_api_glt_fabc_Q474WX7JBBC7GRP9WPMG
I am still trying to narrow down the bags. I tow max 16k lbs
The fixed pressure switch is this:
Any and all input would be greatly appreciated.
Troy
I don’t know if this would work for you but I’ve been eyeing it.
I’ve also been debating just using a regulator for winterizing the camper and possibly tires.
Interesting. What if I forget my phone or it dies, Can i still can change the pressure?
Also, I am still not tracking this: if my bags are set to 5lbs and I want to sit up some tires or use a tool. How does it differentiate between the bags and the o tools or tires? Do the bags use a different solenoid on one of those 1/4 outlets in the tank that determines how much pressure is in the bag? If so, if the tank is pressurized too high, I wonder if that could blow the bags? Am I over complicating this?
Lol, great questions that I don’t have any idea about. I’ve just seen this and then watched a few YouTube videos.
It appears that this only has one outlet that you can control pressure on if plumbed direct to the compressor. It looks like it also has a “full pressure” setting. It looks like there are about 4 presets you can select. If I were to do multiple things with this, I’d plumb a tee and have two outlets. One that’s full pressure from the compressor, all the time when it’s running and then one to the pressure control body.
I supposed you could set it up to run to a separate solenoid bank where you could have the air bags off one bank of solenoids, tires off another, RV blow out to another and then just use the presets to jog between them. Seems complicated but not impossible. I think there are few companies that will make a separate block for the air bags then you can just run the full compressor to them.
Haha. Still researching this. I was googling it. And I was like sweet. I found a money post. Turns it it was me. Haha.
Bump for good measure.
