OEM Winch on 250SD 7.3L with only 1 battery and 1 alternator
just turn off as many items as you can before using winch. you will be fine. Let winch rest on long pulls. My baby tremor has one battery and 12k warn winch.
Great idea, but..... The OEM system has the batteries in parallel. He doesn't "need" a means of isolation. Your desire is personal preference, not necessity.
A means of isolation is not necessary for the winch application especially since the truck should be running while using. For protection of leaving something on and draining both batteries like ivoing referred to as well will require some means of isolation for that case. Of course with two batteries it will take a pretty good load (running winch with truck off) or a extended smaller load to drain both batteries.
