Oem screen conversion
We’re you able to figure out a solution for the air bag light ?
Wondering this also? Was it because it was an F150 bezel and they don’t have the passenger airbag light? The 2022 F250 bezel does though.
Was it causing any issues?
I turned it off in Forscan - it's showing fault because the passenger indicator light is disconnected.
showed my wife the autotech pro vs this thread and she was like keep it oem or oem+ don't do the autotech lol.
I wonder which parts are all oem, maybe everything except their bracket?, and I could just order everything through work discount.
They won't let you buy just the custom bezel and brackets, I tried to get another set to have wrapped in real carbon fiber to match my wheel and they wouldn't let me. :(
oh dang, so the bezel is a custom bezel, along with the brackets, but the lower ac controls, vents, are all OEM part #s. They should sell just the bezel, bracket, bc like you and myself, some of us are not gonna be happy with scratched up second hand stuff or worse f150/250 flipflops like what happened in your case. It would help them with production and the need to procure ebay used parts. At least as an option at point of sale.
They spoke English, not perfect but well enough to communicate. I made sure to backup my Config Prior to them making any changes to it.
Did you save your configuration or AsBuilt file they are not the same ?
ZooDad
I am really really really considering doing this the longer i think about it. I would be doing it to a 2017 SD so im sure there’s some differences but i just have a few questions I’ve read from other places that I didnt see a definitive answer?
-Does access to the door number pad on screen still work for changing codes?
-Does the trailer brake controller work with a trailer? (I read in a couple other places people were having issues with this after the swap.)
-Does the ambient lighting still work? (On and off, idk if you can change colors on the newer ones or not)
-Do the power running boards work as usual? (Deployed, Off, Auto)
-How does the quality of the 360 cameras compare to the 8 inch screen?
They don't know how to do it, but I was able to find the info myself, but long answer short is yes.
Haven't towed my trailer since, but that's not tied to the Sync system from my understanding. So I'd assume yes.
The F-250s do not have color change, but yes the menu option is still there to adjust the brightness of your factory ambient lighting like your 8" screen has and it works
Yes, as those are controlled through the gauge cluster not through the screen. Mine work perfect still
Cameras aren't great to begin with on the 8" screen so it enlarges it. The screen is higher definition than the 8", you're not losing quality you're just enlarging your low res cameras if that makes sense. But they still look just fine to me.
what did it take?
a google search.. lol - when you change from sync3 to sync4 apm your code is cleared to whatever factory code.. so to retrieve the factory code do this, then get the code and then change through screen.
How long did it take you to ship out? I ordered my screen like 40 days ago and still waiting
Took almost 80 days, and i got wrong or missing parts.
Did they at least immediately try to fix it? Or did you have to ship back all the parts that were wrong before they shipped the new ones out?
Took 80 days to get the initial order. They told me it would ship complete and it did not. Was missing OEM vents because they said they couldn’t source them so I bought them. Didn’t come with A/C and Radio controls, took over 2 weeks to get those. They ended up sourcing from eBay OEM parts, they sent F150 lower bezel so trailer controls wouldn’t fit, still waiting on my f250 bezel. So I’m at over 100days and still not 100% its works but still not all there. They do respond, usually at around 5:00pm PST. Some days they respond right away other days it can take a couple days.
What year do you have? If you have a 2020 the harness will not work and you’ll have to stretch every inch of your factory cables to get it to work. Even though i have had challenges, they do try to make it right. So if you don’t get a response right away don’t get discouraged it is legitimate.
It so much faster than sync3, bigger screen is great and wireless CarPlay is a game changer
If I have to outsource a couple pieces and purchase it myself will they atleast do some type of partial refund or is that a no go? Yeah mines a 2020 hoping it is good. Really excited for wireless carplay!!
In previous posts, you’ll see the links to the vents I purchased. I’d maybe check in with them to see if there’s any parts that will be missing that you need to source yourself before they ship to be proactive. But since you have a 2020, you will have a few challenges so I’m hoping that they come out with the extension harness soon because I wasn’t exactly happy on how I had to pack everything behind the dash.
They also sent me the non-digital dual climate controls, which I expected to get from the pictures so I ended up just purchasing the digital ones myself on eBay.
And yes, they will give you a credit if you have to source some parts yourself
1. How tight is the harness?
2. Do you have the part number for the digital climate controls?
