Odd brake behavior when precision backing
My 2020 does something similar, I have never seen in any documentation that it exists but it seems its pretty much like Subaru's hill holder feature. If your on a hill it holds the brakes for a moment so you have time to get on the gas and you dont roll back. Only happens when your on a hill / slope.
Ford calls it Hill Start Assist. Should be information in the OM and plenty online. It should only kick in on a hill, I was assuming the OP was experiencing it on flat ground, but maybe not.
This happens to my 2020 all the time because my driveway isn't flat. Took me a bit to figure out. It's the hill start assist.
The truck will hold the brakes if it thinks it's on an incline.
It will release the brakes if you step on the gas pedal or if you wait about 2-3 seconds.
Most of the time it doesn't bother me, but it is annoying when you are trying to hook up a trailer.
Unfortunately it can't be turned off.
It's the hill start assist, as others have said. However, it's odd to be coming on in reverse. I know I've felt it in my 22 when at a stop sign or red light but only in D. I don't think I've ever experienced it kick on in reverse.
If memory serves there's a way to disable the HSA but you have to turn it off each time you start the truck. Meaning you'll have to remember to turn it off before trying to connect the trailer. I'm sure there's a way in Forscan to disable for good but I haven't looked/researched.
Just like the stop/start mode on other platforms. The things that you can do without, but that’s another thing that’s supposed to help people stay safe.
