I put an aluminum flatbed on my '21 7.3 Tremor, which is about 300 lbs heavier than the factory bed, and a relatively light weight camper and 2 side utility boxes live on the flatbed, so it is constantly under a load. I keep it in tow/haul mode almost always since I'm always carrying load. The tranny keeps in low enough gears when I'm on a steep descent, but as the grade starts to decrease or flatten out, it won't shift into higher gears and the RPMs go way up. I just manually shift into higher gears as the road flattens, which is easy of course, but I'm wondering if there's an issue with the transmissions in earlier Tremor years that keep it from upshifting automatically. Anyone else have the same problem or direct knowledge if it's supposed to be that way or if it's a defect in the transmissions from 2021 MY?
