Could everyone that has had the transmission issue share the build date of there truck? This would help to figure out if this is an issue with a batch of trucks or if its a bigger issue.
I’ve posted about this on another thread here. Exactly my issue as well. My dealer has the parts in hand, going in to shop the 14th??Hi Guys, newbie here. I just wanted to post and say I have an update on this issue. I recently purchased a 2020 F350 Tremor with the 7.3. At 1300km I noticed I had this noise as well. (Took awhile, canadian winters keep the windows up). Just had my truck in at the dealership. Ford has released a tsb for the torque converter. Its a 2 part fix. For some, it will be a loose inspection plate making contact with the converter studs. If that is not the culprit, the torque converter itself is faulty. I unfortunately fall into the faulty torque converter group. Parts availability appears to be an issue and the dealership may not see parts for 3 weeks (minimum). The transmission tech looking at the truck says its ok to be driven for now. If you have this noise, seems like a pretty straightforward fix overall. Unfortunately its a repair on a new truck nonetheless. Hope this helps y'all. Its worth noting, this tsb was released November 27th and didn't even show up on the vin search. Maybe hush hush at the moment.
Any update on the matter. I am still waiting for my TQ Converter to come in. Just out of curiosity, while waiting did you continue to drive your truck. Mine has been sitting in the driveway mostly in case the technician is mistaken.I’ve posted about this on another thread here. Exactly my issue as well. My dealer has the parts in hand, going in to shop the 14th??
I did drive it for a while, maybe 500 miles worth. It's now sitting in the shop waiting on parts.Any update on the matter. I am still waiting for my TQ Converter to come in. Just out of curiosity, while waiting did you continue to drive your truck. Mine has been sitting in the driveway mostly in case the technician is mistaken.
Most of the new vehicles have software that “learns” as you start driving the vehicle. It is adaptive learning and it adapts to each driver in essence. As the vehicle gets some miles the learning process is mostly over and some of these little nuances you feel will go away.Maybe I need to get used to the truck as well. It drives completely different than any other I have had. This is my first time driving anything bigger than an F150. Still learning, so I don't know what I should be feeling.
No, this was a torque converter problem. Had to be replaced.Most of the new vehicles have software that “learns” as you start driving the vehicle. It is adaptive learning and it adapts to each driver in essence. As the vehicle gets some miles the learning process is mostly over and some of these little nuances you feel will go away.
