No more warranty and 9-10 shift sucks
MCTremor
Tremor Buff
South Carolina
Marine Corps Veteran
2020 7.3L Tremor
1968 Cougar XR-7
As the title says, truck is out of warranty now (2020 7.3 with just over 42,000 miles)
Just noticed this week the shift from 9th to 10th particularly around the 50mph range felt like it was struggling.
You can actually feel the truck slow down before 10th finally engages.
Anybody else having this issue or one similar? If its an easy fix I'd rather get to it now before the whole transmission grenades.
  • Sad
Reactions: ccw
Read up on your paper work. I believe the powertrain warranty on the 7.3 is 5 year and 60K miles.
Edit:
I see the 5 year / 60k now
But is there a known cause to this issue?
3 years / 36,000 miles
Didnt buy any extra warranties as I only used it once on my '13 F150 and got turned away by dealers a dozen times before that.
  • Like
Reactions: ccw
The 3/36 warranty is bumper to bumper. The 5/60 warranty is for powertrain. Comes standard.
You might have a $100 deductible if you're over 36,000 miles.
You are definitely still under warranty. If it is an obvious issue, one that the dealership can easily recreate, I would get the dealer to diagnose and fix it.
  • Winner
Reactions: ccw
The powertrain warranty does not have a deductible, I have used it twice....intercooler on my 2019 edge, and a Turbo Coolant leak on my 2014 F150 FX4 Eco.
You may be able to have them perform a reset and relearn of the TCM. This has solved the problem for many with shift problems.
Or if you have Forscan and are comfortable with it, you can try the reset/relearn yourself.
Though I wouldn't delay getting it to the dealer too much. You want to get the issue documented early so that if it comes to significant warranty work you aren't at risk of them saying the issue started post-warranty. If you have a service date for it, then they know for a fact it started before the warranty ran out.
(Depending on how many miles you're putting on.)
I'd just go to the service/techs to speak with them. Then make 100% sure YOU are there when they drive it or you drive it for them. These issues can tend to end up in the "it's normal, or no issues found" department.
We need to be a bit more dedicated as owners to make sure the problem is found/recreated when the techs are working on the truck.
  • Like
Reactions: ccw
