We just released our Ford BoxLink Fuel Jug Mount Kit to give your fuel jug a dedicated spot along your Super Duty's bedside.
It fits 2017–2026 F-250, F-350, and F-450 Super Duty pickups, including Tremor-equipped trucks within that range. You'll need the factory holes in the bedside provided for the BoxLink system, so check that those holes are present before ordering. Chassis-cab and aftermarket beds aren't covered.
Our included brackets bolt directly to those bedside holes. You don't need the factory BoxLink attachment brackets, plates, or cleats, so trucks without that hardware can use the kit too. If factory hardware is installed at your chosen spot, our brackets take its place. Pick any of the four locations: driver or passenger side, front or rear. H-Loop trucks don't need a BoxLink plate conversion kit.
Running a compatible AAL bedside MOLLE panel? The mount passes through its clearance opening and bolts directly to those bedside holes behind it. Check clearance around your bedliner, outlets, tonneau hardware, and other accessories.
The kit pairs our 3 mm 5052 aluminum 10-inch jug holder with steel bedside brackets, plus a ratchet strap and Cordura sleeve to help prevent chafing. We make the holder and brackets here in St. George, Utah.
Raw/Unfinished or Textured Black, starting at $130. One kit holds one jug. Jug and MOLLE panel sold separately. Use an approved fuel container and follow its transport instructions.
Check out the kit here. Questions about your setup? Drop your year and bed configuration below.
