Need help identifying wires
jnguyen237
Tremor Newbie
NC
Army
2020 7.3L 250 Tremor
Hello, new here! I bought this 2020 tremor a year ago used, and i haven’t had luck in identifying some of the wires coming out of my dash console. Can anyone ID these? Much appreciated!
Looks like they had some kind of radio or radios and possibly some other stuff installed there. 2 wires look like coax antenna cables. The little box converts the 12v volt power from the truck to 5 volts for the usb plugs.
Thank you for the help!
I have an additional question if you’re able to help. I have the lariat package with pro trailer assist. There is an aftermarket third brake light installed, but doesn’t have a camera. Do you know if the 2020 came with the bed camera capability in the OEM setup?
Do you have any other camera views? I have a ‘22 and ordered just the chmsl camera, so it may have come with it and later removed for the aftermarket 3rd brake light. I don’t know if the screen would show an error or not if it were disconnected. There is a button on the top row of the center console (right side) that will cycle through your available views.
I’m wondering, have you tracked down where those antenna leads go to? With antenna leads and an after market 3rd brake light; the antennas may terminate at the 3rd brake light. There is an aftermarket mount out there that goes in the 3rd brake light slot and has two connectors for radio antennas. Perhaps whoever traded the truck took that mount and put an aftermarket light in its place. You may have a camera connector in there too! Depending if the original order had the CHMSL that was removed for other accessories.
There may be a treasure behind the light or it could be nothing.
If you have the 360 cameras then I think it came with the bed camera also. I know some of the aftermarket third brake light didn’t have the camera originally and later came out with version that had the camera.
