Plugged into an amp with built-in DSP. No Forscan changes that I’m aware of
Thanks for the response and comments.Having an issue with the ZEN is very rare and we have never seen a defect like the broken plastic, but we will look out for that. In terms of reliability/performance, the ZEN is probably the best sound quality/performance of any module currently available but like someone mentioned above, you have to run your own power + ground to the unit and not use the factory connections for this.
Also, they did move down to a 6-channel output but remember that these are not unique/discreet outputs. All of them are the same, it's left + right and front + rear. So all of the additional RCA outputs on the ZEN are identical in these trucks. You only need 4-channels as that's all you can control anyway from the factory radio (balance/fader). Beyond 6-channels, not sure why you would need/want more. If your system is utilizing a center channel, you should have a DSP that has upmixer capabilities and it needs to start with left + right to do this for sure you do not want to run mono to the center channel, that will ruin your left/right panning in the upgraded stereo.
Figured I would chime into this post as I have a lot of experience upgrading these trucks and have used a lot of these ZENs in very elaborate systems
Honestly ... NAV-TV really needs to update their installation instructions because nowhere in the instructions do they say running an independent ground AND power wire is necessary to avoid / remove potential engine noise. They only put a note saying "if engine noise is introduced through system with the ZEN, match the interface’s ground wire to the aftermarket amplifier’s ground." But when you call them and ask about engine noise issues, then they tell you to run independent wires back to the battery. And if this is the case, why do they leave the Zen module power and ground wires in the factory-mating plug so the customer assumes this is correct, then hooks the plug up to the factory power & ground per their instructions and experiences engine noise issues ?
Anyway, when you connect power & grounding to the Zen audio interface module ... do you run independent power & ground wires all the way back to the battery ... or do you jumper them to the amplifier power & ground wires that run back to the battery ?
Also ... do you un-pin the power & ground wires from the Zen factory-mating plug ... or do you just clip and solder them ?
Appreciate the feedback as a professional installer ... because us do-it-yourselfer's get to learn the hard way without your installation tips.
Uh ... ok.Big fan of the NavTV. Fwiw page 1 of the install guide
"WARNING: Due to the complexity and sensitivity of the OEM Ford A²B®, the ZEN-A2B must be used with amplifiers that are grounded directly to the battery. The resistance to (true battery) ground of the Amplifier(s) must not exceed 1 ohm, otherwise you will likely experience performance issues or damage the ZEN-A2B. "
Additional references to the resistance max for the vehicle ground are found in at least 3 other locations of the 11 page manual.
@SoundsGoodStereo - big fan. Bought a bunch of stuff from you last year for my F250 stereo upgrade.
Uh ... ok.
My 5-channel amplifier does have independent 4 gauge power and ground wires ran back to the battery ... therefore the ground resistance is, and was double checked as less than 1 ohm.
If you look back at my posting a little more carefully, I was referencing their poor instructions about power and grounding for the Zen module ... not the amplifiers ... which is why I pointed out that NAV-TV's tech support on the phone recommended running independent power and ground wires for the Zen Module back to the battery (in addition to the amplifier independent power & ground wires), which they mention nowhere in their installation instructions, it only states to modify the Zen module ground wire to attach to the amplifier ground (which goes back to the battery) if engine noise is present. The irritating part about that, if the customer simply follows their installation instructions, and ends up experiencing engine noise, they will need to pull all the interior panels again and run two small wires back to the battery, which is why I said they need to update their installation manual with these details. Since this is a common issue, it would also be more professional to provide an optional Zen module power & grounding plug with wires you can run directly back to the battery so the customer does not need to clip their Zen module power & ground wires and solder / shrink tube these bare wire connections back together with customer-provided independent wires leading back to the battery.
But appreciate the response ... I think.
As an installer have you had issues with the blind spot and reverse chimes being consisten? I’ve had my truck at a few shops trying to remedy this issueHaving an issue with the ZEN is very rare and we have never seen a defect like the broken plastic, but we will look out for that. In terms of reliability/performance, the ZEN is probably the best sound quality/performance of any module currently available but like someone mentioned above, you have to run your own power + ground to the unit and not use the factory connections for this.
I have about 6k into. Y system and the zen module has been the root of a nightmare for me. I hate the factory system, but I hate all the time has sat I. Shops trying to fix the missing chimes on the supposedly plug and play zenAny reason you know of, of why the navigation prompts would no longer come through the audio system? Used toslink connection method. My installers weren’t able to figure out why the navigation audio wouldn’t come through. The system attenuates the music, as if the prompt should come, but the prompt never comes. I’ve tried adjusting the volume during the prompt, but it was up already. Thoughts?
I decided to just turn off voice prompts on the head unit. I haven’t needed them and this has fixed the symptom at least.I have about 6k into. Y system and the zen module has been the root of a nightmare for me. I hate the factory system, but I hate all the time has sat I. Shops trying to fix the missing chimes on the supposedly plug and play zen
Thank you, i look forward to trying it out tomorrow!I decided to just turn off voice prompts on the head unit. I haven’t needed them and this has fixed the symptom at least.
