Muffler noise on cold startup.
HALL250
Ohio
2022 F250 Tremor Race Red
2018 Toyota 4Runner TRD OR Premium
So, on the past few cold startups my muffler is making noises that sound like a train horn (no train horn installed). After about 30 seconds of warmup the noise goes away. Anyone else had this issue? Any ideas why?
Additional info: it just recently started getting warm here during the day (mid to high 80’s.) I have also noticed a lot of water dripping from the muffler. Enough to create a puddle on the concrete.
Any chance you can post an audio or video clip of the noise?
The condensation doesn’t seem out of the ordinary to me.
no noise but i do get the drips. was told here that it is normal.
Mine does the same on cold start ups in the morning. 20 seconds and it’s gone.
I tried to load a small clip but it says the file is too large. I am also technically challenged.
  • FullSizeRender.mp4
    1.1 MB
    1.1 MB
Yes, that’s the one! Thanks for posting the clip.
So, it must be normal. Annoying, but normal.
Inside your muffler there are channels. These channels create chambers and chambers refract noise, blah blah -- it's one of the way mufflers work. There are other methods but that's the most common.
So what you are hearing is the vibration of either those channels moving or air slipping between the wall and the floor/ceiling of the muffler.
Then when it heats up those seems tighten and seals it off or expands enough that it doesn't vibrate anymore.
You could also be hearing some other component of the exhaust stretching. Most people don't realize that your exhaust can move back and forth half an inch to an inch. If that were the noise you could alleviate it fairly easily by just putting some kind of lubricant on the hangers. (I really doubt this is the case but it is possible, could also be a heat shield from something touching it and vibrating -- I'd check for loose bolts from the headers to the tips)
My personal bet is on it being in the muffler itself.
If it bothers you take it to a good muffler shop and replace the factory muffler with one that sounds better anyway. The 7.3 actually has pretty decent headers on it from the factory so the muffler is really it's choke point. Let her breathe!
Any recommendations on a muffler with good outside sound without the cabin drone? Borla or Flowmaster maybe
Both outside sound and in-cab drone are subjective and the latter is really going to be impacted by your driving habits.
For example, I used to have a straight piped truck. Long tube 1-7/8" headers and dual 4" all the way to the back. Had the truck for probably 5 years before it ever saw the interstate. No drone at all that I'd ever noticed. First time on the interstate -- horrible drone.
Cruising RPM at 80MPH just happened to be the sweet spot and it was obnoxious. I personally had never even noticed any drone prior to that.
If you're really concerned with drone, do a lot of steady RPM driving, I'd look for the more restrictive of aftermarket options wherein you'll get deeper tone but very little increase of volume. Not having a 7.3 I wouldn't be able to comment and I'd caution again that sound and drone are very subjective and what one person says has no drone at all may drive you mad.
I found a muffler shop in Liberty Hill that has done a couple of Tremors. Really cleans up underneath. I’m debating a Magnaflow or a black widow 250.
