Mount Harbor Freight Badland 3T Jack
You should never be under the truck anyway. I wouldn't crawl under a truck supported by a jack ever. even it was a 10 ton jack.
Yup. Jack truck up, place jack stands, lower truck on jack stands, put a pump on the jack to also share the load. Then I crawl under if needed.
I just purchased the Badlands for 25% off with a “no restrictions” coupon ($224), which makes it a no brainer compared to the Pro Eagle at $599. The cost difference just doesn’t justify the increased cost considering they are both made in China, equal quality and the Badlands has some preferred features. I too have been considering mounting options so I am hoping more fabricators will jump on board with aftermarket options. Typically not a big fan of Harbor Freight products, but this is a great value.
I have had one in use for a month or so now and am quite pleased with it. No regrets.
Need a good way to secure it in the bed, though.
I think I’m going to get that grove fab works mount and bolt it in to the crossbin I have under my diamondback cover. The bin really can’t hold that much weight but I’ve overloaded it in the past with no issues on road. Can’t speak to how it’ll hold up off road. The other option is to just get a HiLift jack base and use it with the factory jack. I also wonder if the Badland jack will fit behind the seat of the factory jack is removed. I don’t have one yet. Have to order it. I never really liked harbor freight. Their tools are typically junk with poor tolerances but their recent icon line of hand tools are pretty decent. Their Badland line seems pretty good too.
Exactly! I’m not getting under till I have my jack stands placed.
I think the experience @ccw had would suggest that off road it will probably fall off if overloaded...
  • Winner
Reactions: ccw
where do you guys keep your jack stands, in the truck bed?
I don’t pack stands with me. I just stay away from anything that’ll crush me if the truck falls. I’ll usually throw the flat tire under the axle until the tire is swapped to keep a small buffer if the truck does come off the jack. Since the truck sits so high off the ground, most emergency repairs can be made with all 4 tires on the ground.
Yeah I have stands at home too, but this is an OFF ROAD jack and it's probably going to be the only thing you have when you get a flat or a large branch gets jammed into a control arm, or who knows. When you're in the s%^t with no cell reception, sometimes you do what you have to do. That being said, I'll try not to ever get under ANY vehicle with only a jack, unless there's no choice.
I'm not disparaging this jack necessarily, I just don't trust companies that manipulate their customer review process. Amazon is almost as bad, anymore. Try to find any product with less than a 4 star rating there. We used to be able to (almost) trust the reviews, respond to others' reviews, but no more. Caveat emptor.
Harbor Freight has a lot of great values, if one isn’t concerned what the tool truck fanboy’s think
Yep, the bin does not hold up off-road when overloaded. Can confirm. And this is a very light definition of “off-road”. Really talking about unpaved forest roads.
Looks like the shipping weight for the Badlands jack is 70 pounds. Weight limit in the bin is listed at 100 pounds now, so that jack truly will take up most of the capacity.
Most likely I’ll save weight and money and just get a jack pad and use the factory jack.
I purchased this US Jack and these jack stands after I got the Tremor. It’s over kill but worth every penny of it if I ever needed to go under any vehicles. The bottle jack stay in the bed of the truck under the canister of the RetraxPro cover perfectly.
22 ton jack stands?! Could (conservatively) put 4 Tremors on a single one of those stands! :oops:
That would be something to see!!
  • Like
Reactions: ccw
I have that same jack (and Badlands off road jack), US Jack makes awesome suff and American Made!!! I also have their 6-ton jack stands. You can’t go wrong there they make great equipment.
