How discouraging! Mine just arrived and was going to schedule the install. I can’t stop feeling like this is going to be a mistake!
Sometimes it’s better to just go with your gut!How discouraging! Mine just arrived and was going to schedule the install. I can’t stop feeling like this is going to be a mistake!
I know what you mean I have a set sitting here I keep worrying like yourself if I’m making a bad decision. If I do install them I’ll wire the drl’s to a separate switched power supply opposed to the fuse tap. I have their taillights and 4 banger driving lights and they have been awesome. If I found a set of factory blackout led’s at a decent price I’d jump on it, but all that I have found have been Facebook scammers. Well decisions decisions.How discouraging! Mine just arrived and was going to schedule the install. I can’t stop feeling like this is going to be a mistake!
I have the prototype rears still on my truck, they've been pretty solid.If I have oem leds, is it a plug and play swap for the black ones? I do have the morimoto rears and supposedly have a brake light coming this month. Getting a little concerned.
The shop I’m having then installed at addressed my concerns and told me they’d give me a full refund. They also told me they’ve installed a few in my model/year and have had no issues. During the previous installs, they tapped off the headlight fuse, in the fuse box. None of the other buyers have had any issues. Giving me a little comfort.I know what you mean I have a set sitting here I keep worrying like yourself if I’m making a bad decision. If I do install them I’ll wire the drl’s to a separate switched power supply opposed to the fuse tap. I have their taillights and 4 banger driving lights and they have been awesome. If I found a set of factory blackout led’s at a decent price I’d jump on it, but all that I have found have been Facebook scammers. Well decisions decisions.
What fuse did you tap into?Mine have been in for 6 months and no issues what so ever , went from factory halogens to morimoto XB led’s , did it myself. To be fair my only real worry is the notch you have to put in to get the wire to tap in to the fuse box, had my mechanic give it a quick once over when it went it, he thought it ok.
I see a few other trucks around here with them in when driving as well. Very happy overall.
If you’re talking about the BAP leds, then yes they should be straight plug n play swap.If I have oem leds, is it a plug and play swap for the black ones? I do have the morimoto rears and supposedly have a brake light coming this month. Getting a little concerned.
Yeah I’ve supposedly had it coming every month for the last few. Now they are saying Junesupposedly have a brake light coming this month.
I got my DTC errors sorted. I had to go into the advanced settings on the cluster and turn off daytime running lights. After I did that and cleared the DTC the truck is happy again.I had the Morimoto XB's on my 2020 Raptor with no issues. About two weeks ago I paid a shop to install a set of the Amber DRL XB's on my 2022 F450 Platinum. My front bumper bull bar blocks a little bit of the factory LED low beam, so I wanted to try the Morimoto XB's so I could see better at night.
I have the PTO option so I used the brown ignition on wiring for the DRL wiring. I was worried about the fuse tap as well. I went to pick it up from the shop and first time after turning the truck on one of the drivers side projectors is dead. I paid $900 to get a replacement up front and it showed up today, the new headlight works. Sending back the defective one for a refund.
Now onto the next issue, I'm getting a DTC for both low beams (picture attached). I have factory LED's so I'm wondering if the harness they sent me is bad. I read the manual and tried the non-sequential turn signal to see if that was an issue. Cleared the DTC's and they came right back on next ignition. Anyone else get any DTC's with their lights? Both lights work perfectly, just noticed this when I plugged in Forscan to check something else.
Seems like they have more issues with their lights than they would probably like to admit.Have had my Morimoto XB for a little over two years with no issues.
Now the passenger side has no low or high beams. The LED's around the outside work, but not the low or high beams.
Contacted Morimoto about warranty and I'm waiting to hear back.
