- Nov 2, 2020
- 565
- 1,545
- 2021 F250 Tremor 7.3 Lariat
- 2023 Xpore Roamer1, 2013 Jeep Rubicon 2dr
Differential system explained. Here is a very old movie that perfectly explains the differential. Watch it carefully and everything becomes very clear. Differential operation explained
Remember this simple rule: With an open differential, the torque delivered by each wheel is always the same, but the speed is always different. With a locked differential, the torque is always different, but the speed is always the same.
Remember too: A limited slip diff simply tries to make both wheels turn the same speed by applying pressure between them with clutches. They can turn at different speeds, by overcoming the clutches. They are somewhere between an open diff and a locked diff, depending on the particular design.
Many guys talk about trucks only having "three wheel drive", or all the power going to "one wheel". These statements are NOT true. Compare my explanation of open and limited diffs, and watch the movie to see why.
