Lowering TPMS Settings before purchase
Could of downloaded windows 10 for free (you don’t need to activate it) then used boot camp to install it on your MacBook. Would of saved the money.
Now you’re talking like the guys at the Helpless Desk at my work!
So the factory setting threshold to get a warning and the set point are the same?
meaning, if your tire is at 79psi you get a warnin of low tire pressure? Seems likethere should be some buffer there.
You guys running 60/65 (or lower) all have a warning message constantly? That seems like a pretty annoying side effect of airing down
Mine goes off at 62 in the rear. Finally reset after 20 mile highway run but now it’s back. 80lbs with now weight on the rear tires is way too much.
It goes off around 70 psi when set to 80 psi and the front is 45 when set to 60 ... But using forscan you can change the psi easily to whatever you want ...alot of tuner tools do this it's not a hard thing to change but if you don't have the equipment it is hard to do ... And dealers won't do it unless your buddy buddy with them .... I understand if you under max load you need that tire pressure but it is the most bouncey ride ... 50 to 60 is so much better and probably the best for correct tire wear as well now 40 to 50 would be a nice smooth soft ride but you may run into uneven tire wear in the front with the weight of the engine ... But honestly it shouldn't make a big difference but at so point your going to wear the tire down faster with the lower psi .... 25 psi in this trucks is really soft and squishy the tire is running a flat patch GREAT FOR OFFROADING but not for everyday driving... I used 25 for rock crawling and sand dune driving it did really good but I was scared at 17 psi in the tires it looked like it was going to pop a beam if I did something wrong ... But in my Jeeps I run 10 to 15 psi with out beam locks and have no issues but also the Jeeps are 3500lbs in total not 8k lbs like the tremor but this is just my experience
for sure! but with my other programs often there is a minor glitch in the translation. For the $199.00 for a cheap lap top was worth it. Turned out my wife had to work from home and it got lots of use. There are several other non mac things I can do with the cheap little laptop.
I changed my threshold with forscan run 55 front and 60 rear ( empty ) no idiot light. If I add a trailer I air up according to the weight. My light duty trailers, I add about 10 lbs, my heavy trailers I go max air.
It's not that the dealership Can't do it, it's that they don't Want to do it due to liability. Any dealer that has made the exception to do so has taken that risk. There's only so much a waiver form can hold up.
I've seen units on Amazon that plug-in just to clear the TPMS light (which are less scary than ForScan), and keep in mind you can always check with local libraries for borrowing a PC laptop.
I would not want to upload my truck files on somebodies or a shared pc lap top.
The forscan is very easy, just spend some time on it. There are you tube videos that show you everything. All kinds of settings. Not just tire pressure but lighting, security, alerts........
I honestly don’t own a laptop. I do basically everything off my phone. I have a desktop, but it’s rarely used and I doubt would work for this application. ? And that’s basically all I want to do to it, so to buy the software and some way to use it, and to spend the time and effort learning how to program it, it doesn’t seem worth it.
i hear what you're saying, but you're actually buying the hardware, not the software, which is free. It is worth it if you ever want to diagnose trouble codes or make some minor changes. Compared to the price of your truck, the adaptor and laptop are pennies.
More than 1 dealer has refused to do this,,,,,,I just run with the stupid idiot light....eventually I will change it with Forscan -- like others on here have already done.
I took mine in for rotate and rebalance the tires. They must have changed the pressure on the alarm, I don’t have that problem anymore. I could ask if they did something. Or, maybe if you ignore it enough it will eventually stop?
