Low Tire Alarm
Please elaborate on what the problem was and how you solved it.
The manual says to drive it for 2 minutes at 32KM/hr. 19 Mi/hr I drove one minute from my driveway down the road and back to my driveway.
Press the start button but not start it...so it's on
Press the hazard button 3 times within 10 seconds.. on/off on/off on/off you will hear a beep once (horn) when that is done (heard that)
That puts the computer in a reset mode. (Tire pressure light will flash)
Start with the front tire and let some air out until you hear the horn beep once (heard that)
Repeat the same thing for each wheel. (heard those)
Re-inflate to the desired PSI.
I had to fill the rear with more because they had swapped them and the lower psi were on the back
I am running 77 rear and 67 front.
Thanks Ramey. So this process lowers pressure at which the alarm will activate?
I am assuming so. The whole process takes about 10 minutes or less before starting to re-fill again.
You will see the tire icon flashing after you press the hazard button and will flash the whole time while doing this.
By the way, this is for a 2022 model.
