Loud Engine (radiator fan)
My 2022 just started doing it at 7k miles, its annoying to me and it feels underpowered as well. I just came out of two lemon'd GMC HD Trucks and I'm already having a issue a few months in on this one. What happened to just buying a truck and driving the shit out of it?
Finally got my truck back from the dealer. No more garbage truck.
BTW, there are a few different part #'s for the fan clutches. The one they had in stock did not fit so they ordered this one. Part # in the service ticket below.
It sounds like a garbage truck...
I hard the same garbage truck sound issue. It was the fan clutch. Swapped out by dealer and problem solved. Dealer knew the issue right away so they must be seeing a lot of bad fan clutches.
I was told this week by two different dealers that it’s a 3-5 week repair and the other said 30 days and they truck has to remain at the dealer until the repair is complete. Apparently you have to get in line for the repair, so at this point I’m not even driving the truck trying to figure out if I should just pay a local mechanic to do it. So pissed that I’m dealing with a issue this early on after leaving GMC after two lemon trucks. Maybe I just have bad luck.
Sorry to hear that. Mine was at the dealer for 5 days…couple of days waiting for the part. Hopefully you can get it resolved quicker than a month.
Update: I still haven't had the Balls to drop mine off at the dealership to get mine fixed.... I went to Auto Nation Ford in Katy, Texas yesterday and showed several of the service "GUYS" the service invoice some of you have shared that showed what the dealer did and then replaced under warranty. That was no help for me. They said "Oh Yea, Ford came out with a bulletin on it", its not a problem as it does no harm. Told them that's not how the truck performed the first 6000 miles and i wanted it fixed. That didn't help either. They said they have never seen one that was a problem and never heard of them getting replaced!!! I have included what they printed out for me. So, the guy told me they could check it out and if they found no problems as per their testing then they would mark it in the computer as "CLEARED" which he says means they tested it and there is nothing wrong and if something ever went wrong later and this was the cause of it then FORD would cover the problem...That is likely after the warranty expires!!!! I asked him if I did drop it off and they did find something and were to replace it would he/they then change their story as to there is no problem, he said yes.
So to help others out that have had their fan clutch or other related parts that were causing this issues can you guys/gals list the dealerships and possibly the service managers/techs that fixed your problems. I don't mind driving around to drop off my truck as long as i know I'm not going to get the run around.
I just got my replaced. I'd give them the time to run the test, they knew within minutes that my fan clutch was malfunctioning just by hooking it to the computer. When I first went in they said they had never heard of anything like that, and I was told that I would need to drop off the truck for 3-5 weeks and that they would have to replicate the problem before they could approve a repair. I wasn't happy with the 3-5 week lead time so I went to the Service Manager and explained I use the truck for work and that time frame wouldn't work... I also flexed my purchase history with the dealer for good measure :)
They took the vehicle right back and put it on a test and confirmed the fan clutch was stuck on, this was on Friday. They ordered the part which arrived on Monday afternoon, and I got the truck back on Tuesday afternoon. And for good measure they did a pretty solid detail on it, I don't think my truck has been that clean since the day I bought it. I can also attest to the performance difference and gas mileage drop. The power difference when I got the truck back was night and day, it was almost like the truck was on limp mode when the fan clutch was malfunctioning.
Good luck to you, hopefully you can get it sorted out.
  • Like
Reactions: SJK
Same issue just started at 9500 miles. I am going to the dealer on Tuesday. I have a job on Monday I can't skip. Hoping no damage will be done on Monday.
Dropped off truck at Ford Auto Nation Katy on Monday afternoon. Same service guy, seemed more eager and said he had to be careful in the wording on the service check in he put in the computer. Thursday late afternoon he called and said truck was ready and that the service tech could not get the fan clutch to fail a test and he SAID he told he that the customer has been having major problems and that others have been having the clutch replaced, so service guy entered it as a failed test and replaced the clutch. I will pick it up this afternoon. I guess there is no guarantee of the dealer helping you but my advise is be persistent and have all your information “ like you have seen on this forum” in hand to show them you know what your talking about.
If there are problems after I get it and drive away I will update. Good luck everyone.
Picked up my truck yesterday afternoon, after driving the garbage truck/school bus for the last 8,000 miles it is such a joy to have my truck back in tip top running condition. Night and day difference guys/gals. I have included a copy of the entire service invoice for reference.
Got my truck back last night. Confirmed the fan clutch was frozen up. Repair done and issue resolved. Had to chat a bit with the Service Manager to not wait another week as they were stuck on another car. All good in the end.
100%!!!! Mine is a 22 with 8000 miles and just started the excessive fan noise last night. Unreal that there are so many complaining with the same issue and yet no recall or notice from FORD. Gonna be really pissed if the fan clutch is on backorder. Does anyone know if this is the correct part number? Part #: YB3288 (8A616) - thanks.
See Post #22
