Lightem’ Up! Light them fires & burn them tires!
Rhebster
Tremor Fanatic
Founding Member 📜
Little Rock, Arkansas
2021 Ford Super Duty F250 Platinum
1976 Ford Bronco Sport
Been busy & haven’t posted a bit of work I recently did on my 2021 F250 Platinum (NonTremor).
On the interior I added the Perimeter Plus blinking red security light on side by drivers window (hopeful deterrent) & some upgraded bright led or cooler spectrum visor mirror & map lights from F150LEDs.
On the exterior non-light related, I added the Ford Warn winch with Factor 55 Ultrahook & Rope Guard as I like the clean look of these trucks…used my Upfitter as a relay & used a solenoid & resettable 500A fuse. Now if someone jacks up the front end I’ll go aftermarket. Weirdly I used the winch on 2nd day I had it installed to pull another F250 out of a ditch at hunting camp & this guy was so happy I had it. Truck got new “shoes” & I gave my 35x12.50x20 Nitto Trail Rappler M/T to my nephew. After @ 25k miles the truck had almost devoured the Nittos after following all best practices w pressures & rotating…I don’t tow regularly so this was a shock to me, but it’s a mud tire. Incidentally, the shop I use said I might have 5k left before I had to change, but his1500 Ram would get 25k because the weight difference. Hence, Super Duty has the nickname in my circle as Ole F-Too Heavy;). After reading, reading & PM confirming w members here I chose the Toyo M/T 37x12.50x20 on stock rims with 3/8” BORA Aluminum spacers. 100% no rub, my left side has at least 1/4” of room & right has less as expected yet no contact. For fun, I added 2 air horns on the dedicated air supply (non-compressor) tied into an Upfitter with the help of a wiring harness by my memory slips who (sorry).
The lighting on the exterior has gone nuclear. First, I added the new F150LED Side Badge Amber Light (awesome easy install) with the Starky marker/headlight light tie-in harness. I added the Baja Designs Fog-Combo with bracket that I chose to use Pro (no commentary) on both light options which Apollo Optics helped me special order. The fogs come on w the OEM switch & the Pro Driving on an upfitter with my new light bars. They also helped me chose the right light for more visibility on the side backing up which I wanted installed into the side of the bumper which are the new Diode Dynamics Rock Lights. These are tied into my regular back-ups so work whenever in reverse & my Upfitter wiring for everything facing rear to come on whenever needed. Installing here in particular, depth becomes an issue and Nick caught it as I had other lights in mind. These lights are fantastic (1000 lumen each), illuminating everything the rear facing Rigid lights (installed last year) do not. I added 2 10” Rigid Pro E-Series Amber Combo Flood/Spot lights behind the grill using modified Rigid 2018+ F-150 Behind Grill Brackets intended for 6” light bars. I actually intended to mount 4 10” light bars which fit stacked, but I felt this was blocking too much airflow. At plus, 15k lumens each I figured 2 would be fine with the rest of my additions. Next, I added the Gatekeeper knuckle mounts with Baja Designs S1 Spot lights for turns into “ditchy” spots. These are on the same Upfitter as my newly added A-Pillar Rigid Radiace backlit Scene Pods on the SDHQ mount combo’d with the BAM mount. Last, tire to the “All On Rear” upfitter mentioned earlier are a set of these same Radiance backlit Scene PODs in the Retrax mounting slot w Thule screws & BAM mounts. I’ll attach pics.
Next is new mud flaps from a new supplier not mentioned here so far so standby…first gotta clean up my dirty Defender now that duck season finally ended.
