Lever on EGR(?) cooler and weird noise
STDevil
Washington (the one in the West)
Super Duty
Hi everyone -
I have a question about the lever thingy on what I think is the EGR cooler. When it is at the "rest" position (about the 7:00 position), I can move the actuator rod up and down. But many times, when I turn the truck off, the lever thingy will be in the 10:00 or so position (so the actuator rod is pulled into the actuator), and I can't move the lever, and - and this is the reason for the post - there's a faint high pitched noise coming from somewhere. It sounds and feels like the actuator is pulling the lever thingy "up" to the 10:00 position.
Normally, the actuator will make a gulping whooshing sound and "relax". Then, the lever thingy goes to the 7:00 position.
Yesterday, I opened the hood after the truck had been off for 4 or 5 days. I noticed that the lever thingy was being held in the 10:00 position and I could hear the faint while. As I started at the assembly wondering what might be happening, the actuator made the gulp whoosh noise and the lever thingy was released to the 7:00 position.
Does any onw know what might be causing the actuator to stay "actuated" for so long?
Thanks...
I believe it is a vacuum that actuates it. My guess is it’s holding a vacuum well enough and not releasing or maybe there’s a part that’s supposed to release the vacuum and it isn’t.
When the truck has been off for a while, and you go around it with the key fob, it will do certain startup sequence operations in preparation for starting. One of those things is actuating the butterfly valve on the EGR system. I know mine makes noises sometimes when I walk by, but not always. Perhaps I will experiment to see if there is a specific distance away before it does these things.
