Leveling Kit
If you don't want to mess with the front suspension geometry, check out the PMF reverse leveling kit. I went with the 2" drop that comes out to 1 1/4" drop total to the rear. They make a 1" and 1 1/2" block as well if you want to go even lower. The 2" block leaves a slight bit of rake, but I haven't yet hooked up my 45 gallon auxiliary tank, and didn't want any sagging when I pull my Jeep. May not look like much, but I could definitely tell a difference. Even more so when I had to reach over into my tool box to grab a pipe wrench.
Before the reverse level:
After the reverse level:
I'm not entirely clear on what you have or have not done. A single stabilizer should be fine, the RC unit wouldn't be my first choice but I really don't have any experience with it. Did you do any sort of caster correction....aything with the track bar...shocks?
Nothing but the ready lifts, and I did replace the shocks with Bilsteins. I did purchase a single bilstein dampener shock but did not have it installed to replace the dual RC. Not sure it would make any difference. I just know the tracking after a bridge transition or bump is not ideal. I have even lowered the tire pressure significantly, that helped some. Not sure what else can be done besides try something else or go back to stock and have the rake.
What is your wheel and tire setup. Look great!
Thanks!
Wheels- Fuel D561 20x9, +1 offset and 5" of backspacing
Tires- Nitto Ridge Grapplers 295/65R20
Ok, so just the 2.5" spacers, shocks, and a dual RC steering stabilizer setup. I would start with an alignment, add caster if needed(I'm sure it is needed) and re-enter the front axle if necessary by way of track bar relocation bracket or preferably adjustable track bar.
I did the Readylift 66-2111 1.5” lift on mine. I did grind down the block a touch on each side so it fit flush on the perch. Any more than 1.5” sits too high in the front for my taste. Been almost a year with no issues at all.
how was the install overall? did this require a realignment? ive had this kit sitting on my garage shelf for over a year and ive finally ready to get off my ass to install it. any advice outside of grinding down the block? any issues since install?
