Leveling Kit a Waste?
I had everything installed by the dealer because it was just easier for me. I installed the leveling kits myself on both of my Raptors and it kinda sucked both times. Anyways, I'm very pleased with the results. The truck drives and rides great and much better than I expected after coming from back to back Raptors. I used a 2.5" Ready Lift kit with the trak bar relocation bracket. Looking at it in my driveway which is very flat it appears that I could've gone with 3.5" kit because its not perfectly level.
I just did the same kit, got it back Friday and I feel like my front end looks a little higher or at level. I love that white color.
Thanks, I'm glad that I went with star white. It's looks great in sun. I guess it's just the angle that I'm looking at it from in my driveway.
I bought a superduty for towing not for superior ride quality, some of the kits improved ride quality but limit the payload to 2,000lbs. Of course it rides better, you just made your superduty into a half ton!!!
Which kits limit the payload to only 2000 lbs? I am not sure how a kit that does not change the front springs can limit the payload...
Does anyone see any issues with using this ReadyLIFT leveling kit for the Tremor? I know there may be a little bit of rake, but seems likes a good compromise. Also, would I need their track bar bracket?
I agree with you in concept, but it may bring some unwanted alignment issues since the trackbar will be a smidge off, which means you may be waddling a bit going down the road. I don't recommend going a relocation bracket, but rather the adjustable trackbar. That way it can be dialed in just perfectly.
I'm actually going down a similar route. Although I like the look of a level truck, it's not very utilitarian. At the same time, the stock rake of the truck is a bit too aggressive for my taste, especially since I'll rarely be towing if at all. So I went ahead and ordered a 2.5" leveling kit with an adjustable trackbar, then a 4" block in the rear to make it essentially an 3/4 - 1 inch off in the front vs the 2.5 inches stock. I'll still get a lift so I can fit bigger tires underneath. It's a win-win in my books at the expense of my wallet.
I’m in middle of looking at wicked truck level for tremor. They have a kit that has been installed on a tremor.
I also prefer a smaller rake than factory, but a 4” rear block will lead to additional axle wrap.
So I was sitting here doing the requisite research, after the fact. I bought the ready lift leveling kit 46-2728. 2.5” lift. This one comes with springs and not spacers. Then I started thinking that the Tremor sits higher already than a stock super duty. There’s no Tremor sub-model/trim level option when ordering.
This begs the question, am I literally just trading stock Tremor springs for imposters? Will I wind up at nearly the same height I’m at now, after the install?
Not sure if this has been said yet, but the 2.5" height difference in the tremor is only .5" suspension. the rest is from the tires. so suspension components should get you more height.
I spoke to a nearby Ford dealer that has already installed a fully loaded 5.5 Carli pin top with 38’s.
With the kit being installed by Ford, it doesn’t void any type of warranty, as I’ll be doing the 7/150k premium care on mine.
I’m planning to have this dealer install my Carli kit. Right now I’m just really torn on the Carli 3.5 or 5.5 system. I would really like to see examples of each in person
Just so your aware I am a ford master tech and ford does not warranty any mods to your vehicle. if the dealer told you that that means they will cover it but another ford dealer may not. I have been though it with Ford already. The vehicles are built a certain way with a epa certification and modifying it changes that rating. Just be aware.
Stock tires on a non tremor are 32s correct? That’s only and extra 1.5 inches of height
I don’t expect Ford, or the dealer, to warranty the parts. The dealer to warranty the install and the manufacturer to warranty the parts.
My thought was more along the lines of... Ford being less likely to void a warranty (transmission going out as an example) when the parts were installed by a Ford dealer. Obviously they wouldn’t warranty the shocks and aftermarket parts, but less likely to consider them a contributing factor to a different t component.
Ford could deny a claim but they don’t send out adjusters they do how ever depending on dealer level require prior approval on big repairs like engines and transmissions. They also on prior approval require pictures which one photo they ask for is a 3/4 view of vehicle. ESP will send out an adjuster sometimes and depending on the adjusters input can be difficult. I have never seen ford deny a claim for anything that didn’t have to do with the lift kit ie engines or transmission but that’s not saying can. Usually I always recommend going back to the dealer that installed it because they look bad if ford denies it so they will do everything they can to make sure they don’t.
Awesome information - thank you!
Yes, I believe so. From what I’ve gathered spacing the stock coils, with optional 2”-3” lift absorbers is getting the trucks level, but if you do a 17-19 lift you gain a little more than advertised due to the trucks being lower 20+.I’m working on comparing stock fx4 (17-19) height to the 20+ tremor to see what math is needed to get an answer on the outcome.
@optx002 posted the size of the Super Duty factory wheels in this thread, so 32" is not correct for the 2020+.
The 2020+ trucks are 1" lower than the 2017-2019 trucks. The 2020+ Tremors are 1" higher than the 2017-2019 trucks which makes them approx. 2" higher than a standard 2020+ Super Duty. The extra height you read about comes from the springs and the slightly larger tires.
When you add a replacement coil spring to the front, like the Carli System suspension, the amount of lift is determined by how much bigger the new springs are vs the old springs. Using the Carli leveling springs as an example, the 2020+ Tremors are lifted 1.5", the 2017-2019 SDs are lifted 2.5" and the 2020+ standard SDs are lifted 3.5". It is pretty straight forward math. :cool:
https://carlisuspension.com/product...s/2020-ford-f250-f350-4x4-diesel-3-5-systems/
"The 2020+ Ford F250/350 Platform is the same as the 17-19 but they lowered the front 1″ and the rear 1″-1.5″ depending on the cab configuration and 250/350 designation. For this reason, the only change to the suspension systems will be the stated lift height. The 2.5″ Lift Systems from the previous generation, 2017-19, are now 3.5″ for the 2020."
https://carlisuspension.com/2020-super-duty-rd/
"Measuring a stock Tremor against a standard Super duty shows the Tremor to sit approximately 1-7/8″ higher in the front. The rear has quite a bit more lean on the standard Super Duty but, if averaged, about 1″ taller in the rear.
With this in mind, our 3.5″ and 5.5″ systems on the standard Super Duty will actually be a 1.5″ and 3.5″ System on a Tremor."
Awesome information. It wasn’t so much figuring it out as much as it was finding time to do the research. I’m new to this forum and am still enjoying digging around in some of the older threads. I haven’t decided what I’m doing with my 21, but am definitely enjoying seeing and reading about everyone else’s builds and experience.
Yep, I probably spend too much time researching things on this site and others, but that is what makes this one so good. You get plenty of friendly advice and information, which is not what happens on a lot of the other “enthusiasts“ forums.
Lots of great
Information!
