looking to level my 24’ 250. i’ve decided to go with a Carli suspension kit from CJC offroad. my only problem is deciding which one to go with. the truck has a decent nosedive (pic below), and im not sure which one will level it out best. im thinking 2.5-3” will be the sweet spot for it. i believe… that the tremors have a 2.5” block in the rear leaf springs, i could be wrong. could anyone provide some info on that, or share their experiences with the Carli suspension kits. thanks!
Carli only sells one "level" height suspension, the 2.5/3.5" which nets 1.5" up front on a Tremor and 0" out back. The 4.5/5.5" raises the rear and the front, which technically levels the truck but also ends up much taller all around. Beyond that, they offer 5 different shock packages (Signature, Commuter, Back Country, Pintop, E Venture) but all the hard parts/options are otherwise the same between the kits (although some are optimized towards specific setups). Which shock package you get will be determined by how much money you spend, how you intend to use the truck, what overall ride are you looking for and what additional options you are planning to add.
- Signature: gas monotube shock (similar to something like a Bilstein 5100 series) it's their most basic/budget minded system and also the only one specifically valved to work well with the stock leaf springs (less compression damping and more rebound damping in the rear to manage the stiff rear springs)
- Commuter: steps up to a 2.0 IFP shock, geared towards a more budget friendly build that spends most of its time on road with only light/slow offroad use, optimized for their full progressive rear leaf springs, although it seems most guys with the 2024 trucks are adding a 1-1.5" rear block as their trucks ended a little nose high with these, my 2021 did not have this problem though and sits about .5" rear high.
- Back Country: 2.0 series remote reservoir shock, best "all around" system in my opinion, especially if you value on road performance (unless you've got the $$$$ for the E Venture), performs reasonably well in low/medium speed (40-50 MPH or less) offroad
- Pintop: King 2.5 series RR shock; firmer more planted ride on road (too much for some people), I'd call it sporty, definitely more feedback in the cab on small bumps/chop, but significant improvement in high speed offroad with big bumps/ruts/washouts etc (think 70MPH+ offroad)
- E Venture: 2.5 series RR shock with electronically controlled variable valving, think equal/better on road ride to the Commuter/Back Country with the high speed offroad performance of the Pintop (or better)
I have personal experience with the Back Country and Pintop systems, I have run both on my 2021 which has the rest of Carli catalogue on it (Torsion Swaybar, Radius Arms, Full Progressive rear leaf springs, and shackles), and below is my best attempt to summarize:
The Pintop has an almost sporty feel to it, its very confidence inspiring if you are an aggressive driver and like minimal body roll and tight/precise steering response. It soaks up big bumps at speed and maintains composure both on and offroad. The tradeoff is You get more feedback in the cab over small bumps and light chop encountered in every day driving, some people describe it as stiff/bouncy, but my personal experience is that it's still significantly better than stock in all areas of driving (even when I took off my 37's and went back to the OEM tires/20" wheels). It seems to just get better and better the harder you push it, especially offroad. I found my own personal limits (fear) before the truck/suspension's limits were reached.
The Back Country has an excellent on road ride (Dan T from Carli has frequently said it rides better on road than the Commuter does), it smooths out some of the rough edges you get with the Pintop, and I'd almost dare to say it's closest I've come to the elusive "heavy half ton" ride people talk about a lot. It rides very comparable to a 2023 Power Wagon I test drove and almost bought last year, but maybe a touch stiffer in the rear. It's noticeably more compliant than the Pintop in slow/medium speed settings or while driving on the highway and to the extent I have played around with it on some larger bumps it still handles them pretty well, but a little less confidence inspiring than the Pintop. There's a speed where it feels happy and it gets a little unsettled if you push it harder. Driving around corners theres a little more body roll on the initial turn and larger bumps lead to a little more disruption/rocking side to side. However, I would wager it has enough off road performance to satisfy 99% of users. If I had to put one single descriptor to it I'd say it's 80% of what you'd get with the Pintop (a little more body roll, a little less high speed stability, but also noticeably less bumpy/choppy and much more compliant on road, etc.)
My personal opinion after having run both:
If I had originally had the truck built with the Back Country shocks, I probably would have never changed anything (you'd likely never feel like you were missing anything), but now that I've driven both, my preference probably leans towards the Pintop, but that is a highly personal preference as I didnt really mind on road compromises that came with better offroad performance. I originally took my Pintop shocks off the truck as I had sold my 37's and was planning to sell/trade the truck in on something new, but didnt have much luck selling them (although they are still for sale) and now that I'm keeping the truck for the foreseeable future I'm probably going to reinstall them at some point and try and sell my Back Country shocks instead.
Hope this helps!
