Let’s talk super chargers and gear ratios
Tech
Tremor Buff
DFW
2021 F250 7.3 Tremor
Adding a super charger is something I’m going to consider once my truck is closer to the warranty period ending. I have read several reports of increased fuel economy and quite honestly adding a bit of additional range when towing our camper and boat is a factor in why I’m wanting to do this.
That being said, with the significant increase in power and torque with forced induction would it make sense to pair that with taller gears as well, such as 3.73 or 3.55s to get some additional fuel mileage gains?
Just something that I wanted to get y’all’s thoughts on.
I’m curious on why not a turbo? I’m guessing ease of install?
I’m just not aware of any turbo kits at this point. Also I thought that super chargers make power at lower rpms which in my mind would be more conducive to towing, but I’m not sure if that is always the case or that’s just my brain making it up.
I'v read a few articals I'm trying to get some info about voiding the warrenty if you instaull a super charger on
a 7.3 one of the articals Roush Racing instauled a blower and pulled some heavy equipment around made a lot of torque and HP maybe Ford put there blessing on it and not mess with your warrenty I would do it in a heartbeat. I think I would do a turbo
In my humble opinion I vastly prefer superchargers over turbos, much cooler engine bay less chance of a failure no engine oil going through through those crazy exhaust temperatures etc. Both can add significant power and efficiency.
you don't think a blower makes heat or trashes your oil they put intercoolers inbetween the intake and the
blower the blower uses more oil than a turbo that being said I had a 3.5 ecoboost it was the best towing truck
it put a 6.0 I had to shame thats not saying much
I don’t think I’d worry about it with the 10 speed. I haven’t looked at the kits for the 7.3 but a lot of modern super chargers have a bypass that effectively unloads the pulley at highway speeds under light load.
I honestly don’t think with any forced induction you stand to gain any efficiency on that thing. 4.10s will keep the drivetrain happier too with all that extra torque.
Intercoolers are to cool, the oil in a supercharger is seperate from the engine oil unlike a turbo. Superchargers also do not make heat like a turbo at all, a turbo is run off your hot exhaust gasses a supercharger is run by a belt.
That said superchargers usually end up not saving anything on fuel as the parasitic loss from the belt eats up the extra efficiency. They do make amazing power gains for any use however.
That's why turbos are used for efficiency gains, they recycle energy from exhaust to spin the turbo. Both devices end up doing the same thing, jamming more air into the intake.
if its cooling the oil it would be a oil cooler on the ones ive instauld the charge runs through it. a turbo is more efficient it dosent take any HP to run it if they didn't work the high end auto manufactures wouldn't use them
