Leaking DEF ?
ThreeLRanch
Tremor Fanatic
Texas
2021 F250 Lithium Gray BO W/HCTP
My wife just saw some white beads on my exhaust tip and then I looked underneath the truck and saw a little bit of oily stuff on the section on exhaust pipe in the pic and there seems to be a lot all under the truck but I haven’t had any issues with it or anything. I do remember another member that had something similar but couldn’t find his post , if I remember right he had a big spot under his where it leaked.
Mine is oily and black and sure that it shouldn’t be doing this so I guess it’s time to take it in 😖😖😖😖
DEF - Diesel Exhaust Fluid is clear and crystallizes when exposed to air. I’m no expert but don’t think DEF would turn oily.
Yes I am aware of that and if you look at the pic of the exhaust tip you will see that there’s some white beads on it that will be DEF , the oily stuff is on the exhaust pipe after the DEF system.
