G
Guest6749
Guest
I get 19 on average unloaded and the 7.3 gets around 14 MPG so the delta favors me in diesel over 1000 miles. Also, here I am paying $3.89 per gallon and regular unleaded is only around .20 cents cheaper give or take a few.
1000 miles divided by 19 MPG = 53 gallons x 3.93 = $209 with diesel.
1000 miles divided by 14 (I'll be generous) = 72 gallons x 3.27 = $235 with gas.
To be fair, im a diesel fan, but hard to justify the extra 8k over the 7.3 FOR ME due to what I plan to tow... my 6k lbs boat... hell a super duty was hard to justify over an F150 except the Super Duty was cheaper at the end of the day for SUBSTANTIALLY more truck and a bad ass motor.
BUT lets use your numbers of ~$25 more per 1k to fuel a 7.3....
8000/25=320... 320 THOUSAND MILES to break even on the 8k cost of the diesel...
Lets go further and say for some reason Diesel becomes cheaper than gas and it costs you $100 extra per 1k to fill the gasser. Thats 80k miles to break even. Substantial, but not as daunting as 320k miles to break even.
Ive seen the figures of 150-175k miles thrown around using national averages. Thats substantial and likely something 98% of drivers will ever even hit with their trucks. So, again, in theory, a diesel never pays for itself on fuel savings alone.
On a single wheel truck diesel vs. gas doesnt gain you much on tow capacity because you are tire and axle limited...and diesel usually hurts you on payload due to its weight over the gas motor. I think tow capacity difference between 350 gas and diesel is only 1k pounds(20k vs. 21k), but maybe im not remember the tow guide completely.
NOW if you NEED something like a 350 dually or 450 dually for the loads you tow then you need a diesel. No questions asked...
If the 7.3 didnt exist I would have likely ordered a diesel because the 6.2 is meh at best. Same with the gas motors in the HD's from Chevy and Dodge...meh... I would be in a diesel something(not a Ram for sure, but maybe another Denali Duramax). But the 7.3/10spd/4.30 gear combo I think gets pretty dang close for a lot less cost, a lot less possible maintenance, etc...
