Jacking front end with Carli front diff cover
ccw
Carpet Delete Missionary
Founding Member 📜
Retired Mod ⚒️
Washington
2022 F-350 Tremor 7.3L
1980 Mazda RX-7
Does anyone have any suggestions for jacking up the front end of the truck and being able to get a jack stand placed with the Carli diff guard installed?
I’ve seen this video from PTT Arod:
To jack up the drivers side he uses the front differential as a jack point and that leaves room for placing a jack stand. Makes sense, but the carli diff guard hangs lower (by design). Don’t feel terribly comfortable jacking on it because that’s putting the force straight into the lower cover bolts. The housing itself is super strong, but those bolts were never intended to take a massive vertical shear force.
Not a blocker today, though would have been convenient, but I can see needing to get a jack stand under there at some point.
I jack from my diff cover frequently. That cover takes massive impacts on rocks bearing the weight of the truck and forces multiplied by the inertia of the vehicle. I have never seen the bolts shear, even when impacted repeatedly. Jacking is a non issue relative to these forces.
Ok awesome! Good to know. Thank you!
