I have 37x17 tires and 17x9 wheels on my 2021 Diesel Tremor with a full Carli 2.5" suspension, front torsion bar with SS end links and dual steering stabilizers.
I have had the wheels and tires on the truck for more than 7000 miles without a single problem. If you are getting wheel shake, I do not think it has anything to do with the tightness of the calipers unless your wheel weights were knocked off. I think your installer is grasping at straws, as the only issue with tight calipers would be rubbing on the inside of the rim, which would be very noticeable when you remove the wheel. I am not sure what you mean by ride quality, but mine drives and rides fantastic with the extra rubber height of the 37x17s.
Have you added dual steering stabilizers, Carli or otherwise? I was told to have the smoothest ride, you need both upper and lower, as they oppose each other and are adjustable.
Wheels: Fuel Zephyrs 17x9 with 1mm offset and 5" of backspace.
Tires: Nitto Ridge Grapplers 37x17x12.5 Load Range D
Left Front:
Left Rear:
