So I recently noted that my rear seat heater on the drivers side would only work if the rear seat bottom was folded up or the rear seat back was folded down. Any attempts to put either the seat bottom down or the seat back up resulted in the rear seat heater light turning off. Once I cycled the key, I could restart the seat heater as long as the bottom was up or the back was down. I eventually discovered that the screw shown at the red arrow had eroded through the outside cable insulation where the red circle is and the insulation of one of the control wires going from the seat heater module to the seat bottom.
I was able to split the outer insulation and apply some liquid electric tape to missing insulation on the inside wire. I then wrapped everything back up with Tesa tape and applied a rubber end cap to the offending screw. I also used a cable tie to the nearby wire bundle to pull the affected bundle towards the center of the truck.
The pictures are oriented with the truck rear to the upper right and the door is to the lower right.
I’m posting just in case anyone runs into a related issue.
