Installed Titan XXL Replacement Fuel Tank - 55 Gallons on Board
Any ballpark on what a shop would charge to install one of these and is there any effect on warranties?
I had Maplecrest Ford Mendham NJ (Where I bought my truck and is a Titan Installer) do this. If I remember correctly it was about $400 to install it.
I'd like to hear definitively from people who have installed these exactly how much lower than stock each of these brands of tanks hang down.
You can see it in my picture below ... you lose the skid plate ... and it is about 4 inches down. Titan supposedly gives a lifetime warranty (check with Mike Deford at TItan). I am not planning to do heavy-duty off-roading with my truck. If I were .... then I would have a new skid plate added (which would be expensive I assume) or I would not probably do it.
I want one!!!
I had one installed. The tank works and doesn't affect ground clearance. I drove off-road a lot. It cost around $450 for install. Check around, I had quotes from $350 to $500.
The challenge is neither the recommended installer nor the folks at Titan that I spoke with were able to recommend anyone other than Ford to modify the "miles to empty" gauge via computer. Titan finally recommended a third party hardware with App that can be installed in the onboard computer diagnostic port, but seemed like too much fuss.
My local Ford dealership sells very few trucks so they told me that they'd need to 'fool around with the computer to adjust the 34 gallon tank to 55 gallons but didn't know if they'd be able to at $240/hr. I recently drove from CA to UT and each Ford dealership that I stopped at was booked 1+ week to 1+ month (St-George, UT) out on service appointments so no-go there either.
Anyone have a Ford dealership that has dealt with fixing the "miles to empty" gauge after the Titan install?
MIne would not ... or said that It was not needed ... you need to use forscan and get the cable to attach the car to your laptop ... it is relatively easy
This guy did it by himself. Might just cost you a case of beer ?.
Voiding warranty is a good question though. I feel like anything we change could relate to something else if you reach hard enough. Lifts, bigger tires, exhausts, cold air intakes. They all have a chance of getting blamed for something else going wrong.
I looked on the titan website for a list of installers ... the Ford dealer where I bought the truck was listed as an installer (Maplecrest Ford in Mendham NJ) so I had them install it. They told me that it could have warrantee issues related to the fuel systems ... but I would go ballistic at the dealer if there was a problem with the work they did ... I do not think there would be problems and I have had 0 problems with the install ... except I forget what a gas station looks like up close ... I am getting about 1010 miles per tank (diesel). They charged about $800 (but they dealt with the extra diesel fuel etc... so I felt I was worth it.) it does hand lower than stock and the shield can not be reinstalled ... you can see the tank in my profile picture.
Oh someone commented that the charge at the gas station would be shocking ... but I only go once a month instead of three times so it works out LOL.
I’m new to the diesel world and will have my first diesel around the new year. I was under the impression that it’s not good to let diesel fuel sit to long In your tank, especially with cold temps as I’m your N.Y. Long Island neighbor.
I’m interested in modifying my rig with just about everything and this was something I wanted to do also. I thought If I did this I’d leave a 1/2 a tank and not have diesel sit around forever. Figuring I usually never bottom out my tank ever. So kindly explain your views.
I’ve been really busy with construction project at my home so I haven’t been reading full posts. Also is your gas reader is accurate. Sorry if you already posted it. Love your sick Mustang. Thanks, Don. ??✌️?????????
Wondering if there is something similar for the 7.3L godzilla engines
They don’t make larger tanks legally for gas engines. Diesels don’t catch fire easily. That’s been what they’ve said on this site.
THat's too bad. I would love to have a 1000miles+ in the tank...
Transferflow makes tanks for plenty of gas trucks. Just not the 250. You can go request they make it tho. There was a thread somewhere on the FTE forum about it. The more we can request one for the 7.3 the more likely they will make one eventually.
