I think I fd up on an order
NavyChief
Tremor Buff
Palm Bay
Navy
23 F350 Tremor 7.3
23 F350 Lariat 6.7
So had a good deal come up and thought I would try some 35s so I ordered a set for a really good price but they are 12.50s. It shows recommend 9.5” rims and the factory is 8”. I’m pretty sure I can’t stop the order so I’m on the hook. Maybe an excuse for some Rhino wheels lol. Anyone run wider than stock?
I should have just stuck with the stock size but hindsight and all that. 35x12.50/20 I got the set for 705 shipped to my door. I guess worse case is I put them on marketplace if they don’t work.
Almost everyone that runs after market wheels on here gets wider than the factory 8" wheels from what I've seen.
Not sure what wheels you have but if they are factory 18" Tremor wheels you should already be running 35s from factory!
1) Make sure they are not 20" tires going on 18" wheels.
2) You can stiil run a tad wider tire on a narrow wheel. There might be an increase chance of tire wear.
3) Buy wheels that support the wider tires.
Quick.searxh.
Yes, a 12.5‑inch wide tire can go on an 8‑inch wheel in many off‑road setups, but it is usually at or just outside the tire manufacturers’ recommended rim‑width range
What manufacturers recommend
Most modern 12.5‑wide light‑truck tires (for example, common 35x12.50R20 sizes) list a recommended rim‑width range of about 8.5 to 11 inches, with 10 inches as the measurement reference. Tire size guides that aggregate specs likewise show 12.50‑series tires typically starting at 8.5‑inch minimum rim width. That means an 8‑inch wheel is technically narrower than what many manufacturers publish, even though many off‑road users still run that combo
Real‑world off‑road practice
Off‑road communities commonly run 12.5‑wide tires on 8‑inch wheels because the narrower wheel helps keep the bead seated when airing down on the trail.
Yeah I think your only problem is having a big box type shop mounting them because the specs say you need a wider wheel but I’m sure if you go to one of those little corner tire shops they won’t even look it up
I’d worry less about “recommended” rims, than “acceptable” rims. Have you gone to the tire manufacturer’s website to see what wheel width is approved with the tire?
See the table below (for Toyo AT3). Toyo highlights the “preferred” rim size, which should optimize tire performance and length of service, but it’s safe to run significantly smaller or larger rims.
the shorter sidewall of a 35 might come into play depending on how flexible the sidewall is. Verify the wheel diameter (18 or 20... you never said you have an actual Tremor & do what Whaler suggested on the spec sheet from the manufacturer of the tires you bought. How you use the truck will matter too. Share those details if you want opinions.
It’s a non Tremor with 20x8 wheels. Mostly will be just weekend driving now that I’ve moved to another truck for daily. Once they come in I’ll see how I like the look before I get them mounted but yea there are a couple small tire shops here I can use.
I've ran 33x12.5 on my 7" wide Ranger wheels for quite awhile, no issue. On my Rams I've run 12.5"/13" wide tires on 8" wheels forever before going to 14" wide tires on my 8" wide wheels (admittedly 42"s on beadlocks, mounted myself.) I also ran 285 (~11.5" wide) Duratracs on my Chevy 2500 6.5" wide wheels. I've never had an issue or complaint. I would actually say 8-8.5" is perfect for a 12.5" wide tire.
