House Battery Setup
The dual batteries are connected in parallel from the factory though, correct?
I have dual batteries and Winch on my 7.3. The Right side battery is used for the trucks Starter and Winch. The Left battery is what I planned to use for the Inverter. I've chosen a Wagan 2000 watt Pure Sine Inverter. My plan was to run a wire from the battery to an Anderson plug in the far back of the bed. (25'?) For the Ground, I thought I'd run (maybe 5') from the Plug to the trucks Chassis. My plan is to carry the Inverter in the cab of the truck, just take it out and plug it in when I need it. I realize I need to use Marine grade pure tinned copper wire. The Inverter Manual calls for 0000 gauge wire for a 25' run. Can that be right ??
I imagined 0 gauge maybe, I've never seen 0000 in anything.
I wouldn’t doubt that number. 2000W will pull around 166 amps from the battery at full load.
So, still looking at the same size house battery, but switching to Li. I'll see how it goes with 22-25ah, but the smaller size leaves me the space to maybe add a second.
Ultimate goal is enough juice to let me charge small electronics over night, power some campsite lights (under an eventual canopy), and maybe run a small 12v fan to keep air moving in the shell.
So back to my last question. I know I need a DC/DC charger which will take a power run from under the hood. But do I need a second power run to operate an inverter? I'd like the inverter to run off the alternator when the engine is running, but also available off the house battery when the engine is off. Is it just the single run going Alternator>DCDC>Battery>Inverter, where the battery is just a buffer along the circuit when the engine is running?
