HELP!?
surfscottydog
Tremor Fanatic
Santa Cruz California
Handsome Jack. 2022, F250 Tremor with Four Wheel camper, Fleet, White Knuckle rock sliders, Buckstop rear bumper. All the bells and whistle‘s that I might need
Subaru Outback
So, I did a stupid thing. I drilled a hole through my center console all the way to run some wires. Before I did this, I “thought“ I checked for any possible wires that might be in the way that I couldn’t see, and as far as I thought, there were none.
Now, after the hole is there, my back up camera isn’t working right. All I have is a black screen that I can vaguely see images through.
Did I do this by drilling through and nicking a wire, or is this coincidence?
The hole where the wires go through are on the rear passenger side of the console. The wires cone out just above where the transfer case ends and the driveline begins
  • Like
Reactions: ccw
I believe there’s a main harness running under there. I’m in the middle of moving right now so I don’t have access to the photo of when my console was removed. I’ll see if I can find it later tonight! :)
Hate to ask the obvious question but it isn't just bad lighting with our bad quality back up camera is it? I only ask as it appears that you are back up to a garage here but lots of light in the cab. This often messes with the camera lighting and it looks like crap.
Is everything else on the screen look correct?
Edit: Do the other cameras look good still?
No, it’s just the camera gone bad. Before I did this, it loo really nice imo.
  • Like
Reactions: ccw
There’s a very large harness under that console on these trucks. It runs from the BCM, then splits over to the drivers side.
Great, maybe I can take the safe apart and it will come out in pieces, I don’t know how to remove the whole center piece without special tools or F’ing it up
we are talking about the big part of the console right? like where the big arm rest is ? if you want to check for damage, remove the 2 lower side pieces of the console, also remove the rear cup holders and the back of the center console(power port etc part). then you should be able to atleast get a decent view of the harness.
I will definitely give that a try tomorrow when it stops raining
Look at an install video for the half console safe. I will try to find a link and add it. For that one, you slide a plate under it, so you have to take off what Forman mentions above.
Add link:
Add link:
Thanks for this. I think it will help me a lot with the removal of my console.
@surfscottydog I found the pic for you! :) I cannot recall, but the blue connector may be the video feed for the rear of the truck. Depends on where your drill bit hit exactly, possibly one of the canbus network wires/harnesses within this particular area.
This looks very helpful. I’ll go on YouTube and see if there’s any better information than what Ibeb sent me on how to take the console out. Thanks for all your help
Well, I took all the advice I could. I removed the center console and found two wires that I injured during my lapse of judgement and fixed them. I crimped them with wire connectors since they were stranded copper wires. Long story short, it still doesn't work and now I am going to go to an aftermarket camera and have the professionals install it. I feel like such a loser right now.
However, Thank you to everyone who tried to help me, you are all great!!
  • Sad
Reactions: ccw
stranded copper? as in just regular copper wire? Do you have the color of them? what connector they went to etc? Sorry I would want my OEM stuff working. not putting in an aftermarket camera.
