Help w/ engine choice - the dead horse thread
but, the 6.7 will always have more resale value so it is not like its money youll waste
It’s also the opportunity cost you incur while that money is invested in the engine. To soop’s point above, if instead of having that money invested in a depreciating asset you put it into the market in some way, you could have more than the original $8k when you sell your truck.
Or you could put that money into mods, trips with said truck, other life goals, etc while you’re using the truck rather than waiting to sell it and recoup that money.
So while you may get a sizable chunk of the initial $8k investment back on resale, it’s more complicated. Certainly, even accounting for resale, it isn’t free or cheap to go with the diesel instead of the 7.3.
I don't think it will sell for $9k more than the 7.3.
Just for shits and giggles I blue booked identical 2020 trucks, one with a gasser and one with the diesel.
Difference was $6159 more for the diesel. Make your own choices. I personally chose the diesel, and part of that decision was increased resale over the gas. The other part was that I drive a Freightliner every day for work and I know how to take care of my fuel and LOVE the horsepower and torque of a diesel.
But to your point, if the diesel cost $8000 more than the 7.3L and resales for $6200 more… The argument flounders.
By all means, one should get whichever engine their use case demands, and feel content in their choice, but keep in mind a percentage of the common knowledge bandied about in these forums is maybe not so much fact as strong assertion.
Same thing with mpg. I do not care what people say, a 7.3L FX4 with 3.55 gearing gets the exact same mpg as a 6.7L Tremor with 3.55 gearing. It’s not up for debate, it’s fact. Now, that same FX4 will in no way have the low-end availability as the 6.7 for tasks like rock crawling, towing, etc… That is not debatable either, but the assertion that it is the engine that is responsible is untrue.
Perhaps if all the environmentals were stripped off the diesel, there would be an easily drawn distinction between the two platforms. But… As they come from the factory, the 6.7 is not effectively more efficient or more valuable; it's just more powerful and significantly more maintenance intensive.
By all means, one should get whichever engine their use case demands, and feel content in their choice, but keep in mind a percentage of the common knowledge bandied about these forums is maybe not so much fact as strong assettion.
Same thing with mpg. I do not care what people say, a 7.3L FX4 with 3.55 gearing gets the exact same mpg as a 6.7L Tremor with 3.55 gearing. It’s not up for debate, it’s fact. Now, that same FX4 will in no way have the low end availability as the 6.7 for tasks like rock crawling, towing, etc… That is not debatable either, but the assertion that it is the engine that is responsible is untrue.
Perhaps if all the environmentals were stripped off the diesel, there would be an easily drawn distinction between the two platforms. But… As they come from the factory, the 6.7 is not more efficient, or more valuable; its just more powerful and significantly more maintenance intensive.
That’s not really an apples to apples comparisison though? Doesn’t the Tremor come with 75 profile tires vs. 70. Also I thought Tremors also came with wider tires and definitely different aero. I don’t honestly give a crap what motor someone buys. See my previous post. I think all three are actually reliable. I don’t quite get the folks with hateboners in this case. I also don’t quite get the 6.7 is the answer to every question crowd either.
For my money I don’t understand not jumping to at least the 7.3. I can certainly understand folks not wanting the extra costs associated with the diesel unless you do a lot of towing.
$10,495 for the 6.7 option. If 2 identical tremors one 6.7 the other 7.3, no towing, best mileage for each, say 100k miles, i bet the 6.7 would cost more in maintence and repairs including def than the cost of the 6.7 option so i believe the 7.3 would resale better. I have a ‘21 6.7 f550 great truck good power though less power than f250 f350 and non cab chassis f450. But i didnt buy it, the company did. Hopefully my 7.3 tremor get here this coming week. Personally im over diesels for my personal vehicle, just sold MB sprinter got tired of waiting for another def issue from sitting, i usually only drive my personal vehicle maybe once on a weekend and the van wouldnt fit in my garage, too tall 😔
My point was that a good percentage of anecdotal fact is not really fact at all. I’m in no way troubled by the variance in tires as every individual argument on the topic is equipped just as individually. Swap the tires, do what you will with the plastic chin strap and run an empirical test. I’ll put $50 on a comparable outcome.
I have said repeatedly, across various threads; it doesn’t matter what you buy if it makes you happy. In the event that your specific use case necessitates a higher capacity, then embrace that 6.7L and go forth, secure in the knowledge of your torque based supremacy. It’s an awesome power plant, enjoy it.
For literally everyone else, there is the 7.3L. It is not inferior, it is not less desirable, it is not less value in terms of resale, it is not anemic or under-powered relative the platform, it even gets gas mileage equivalent to a mildly modded 4.6L Mustang… Ask me how I know.
The fact is, >90% of Tremor owners do not need and will never use that power they swear is necessary to get them through the day.
There really is no losing here, unless you find yourself in a 6.2L, and then I guess you’re SOL.
Love the one you’re with.
All the posts about how long it will take to recoup the upfront money v. the better mileage are fine. The power and torque discussions are fine. The big block v. the diesel fan clubs are fine. I just got back pulling a trailer with a chord of wood about 50 miles up and down hills, and the transmission never got out of 10th gear. That Godzilla is an animal!
It’s all irrelevant when you go with a extended warranty. As you should either way when your dropping this kinda coin!
Unless you believe that 60K miles is enough to work out any engine issues and you are willing to pay out of pocket for repairs since on average they will cost less than the price of the extended warranty.
Small note: that price is over the 6.2L base engine. The 7.3 is a ~$2000 upgrade over the base 6.2, so for Tremors, that come with a 7.3 by default, the diesel is a ~$8000 upgrade.
Lol! Hateboners everywhere!
I am not saying any of you are wrong here, they are all valid points. I had a 6.2 and it sucked for mileage. I am quite impressed I can get 20 from a big ass truck. I love it and I am not at all regretting the decision,
You are right about this, the website is misleading. Just used the Ford.com builder - Built a Lariat with the Tremor package included and the diesel looks like it's $10.5k over the 7.3:
But when you play around with it you can see it's ~8k
To the "irrelevant" comment regarding service costs on the diesel, while this may be true for many owners who don't intend to keep their truck that long - I actually plan to keep my truck well past any warranty (I'm thinking at least 10years of ownership at this point) so long term reliability is huge for me.
Are you sure about that? Just used the Ford.com builder - Built a Lariat with the Tremor package included and the diesel is clearly $10.5k over the 7.3:
Also to the "irrelevant" comment regarding service costs on the diesel, while this may be true for many owners who don't intend to keep their truck that long - I actually plan to keep my truck well past any warranty (I'm thinking at least 10years of ownership at this point) so long term reliability is huge for me.
long term is when it pays off if you do 200,000 miles your gas mileage will pay you back
I ordered a 6.7 because I want power and fuel economy. Powerstroke can go about twice as far on a tank. I know there will be maintenance and harder to work on but if the motor explodes after warranty, I’ll drop in a 24v Cummins. But I’m pretty sure if you just get a cp4 disaster kit, the 6.7 is a tank of an engine
Since we are talking MSRP numbers, yes. I bought my truck with Z plan. So the upgrade didn’t cost that much. Though roughly proportionate expense wise.
Hey guys,
New member here. I’m in the process of ordering a 250/250 Tremor and am conflicted on the engine option.
The 7.3 would be perfectly adequate for my needs.
Having said that, I have zero concerns with paying the 6.7 premium, understanding the increased maintenance costs, etc. if that means better overall reliability.
It seems I keep reading and seeing videos of folks w/ the 7.3 engines misfiring/throwing codes and it has me concerned with the short term, and maybe long term reliability.
I drive 60-80 miles per day and need my rig to be reliable every single day. (Not towing a big load on a regular basis). I simply can’t afford to have it sit in the shop 30 miles away with parts that may not be available for days or weeks.
Thoughts?
I love my 6.7
Never considered a 7.3
My first diesel ever and I’m 53 years old
Love the power, acceleration, smoothness and it’s super quiet inside.
I occasionally tow a 14k fifth wheel but otherwise I’m taking the kids to school and cruising around town mostly and it drives real nice and I get 16mpg city.
When I do tow….it’s a breeze!
Truly a beast of a truck with the 6.7
With all that said….to each his own
