Help my fix easy exit?
blumhagen
Tremor Addict
Canada
2022 F350 Platinum Tremor w/6.7L Powersmoke
Picked up the truck yesterday. Easy exit worked until I set my memory #1 then now it doesn't move the seat for easy exit only the steering wheel. I know I've done something wrong just not sure what. Are you able to set what the easy exit position is?
Look in settings on your convenience screen (between tach and speedo). There should be a check box for easy exit. If it’s checked set your peddles wheel and seat again and hold down the 1 2 or 3 button until it dings You should be set then.
Yep it is checked. It worked when I picked up the truck, but what I'm saying is once I set the memory, it started to only move the steering wheel for easy exit, it no longer moves the seat for it. I double chcked and it' still check.
