heads up to winch installers - nuts may not fit in the winch body
knaffie
Tremoraholic
Zephyr Cove, NV
2022 F350
I installed my winch last weekend. The passenger side upper nut was 1/4 hole off, meaning I could not get a bolt in it. The passenger side lower would thread a bolt in, but it was binding against the winch body. The driver's side had room to spare.
After a lot of investigation, we found that the winch casting on the passenger side must be machined slightly wrong, leaving too much material for the nuts to slide all the way in. Rather than screw around with new parts, I took the nuts to the bench grinder, removed a little bit of material, and kept on with the install.
I suggest you check these BEFORE you are holding the winch up in place and trying to reach around and thread the bolts in.
Per the directions those nuts are directional and only fit in the casting one direction. I also had some in wrong and found a similar issue. Turn the nuts around and they fit fine.
I'm very aware that they are directional. I had them in the correct way. Note the pictures which side I had to grind. The short side. Turning the nuts the other direction would have made the fit problem worse. I'm sorry you were unable to figure that out by looking at the pictures.
Thanks for posting this, very helpful.
How long did the install take? Thinking about starting mine tonight.
A lot longer than expected. Three of us working on it. Not in any particular hurry, but working steady. Two of us are very mechanically competent and the other is a full-time mechanic. Took us a solid 6 hours. Then an hour of additional troubleshooting time when the stupid bullet connector pulled apart while being zip tied and nothing would work. That got butt spliced and a ring terminal on the end that attaches to the motor.
The mechanical said he would easily bill this as a $1000 install. Getting the bumper on and off with one person wouldn't be fun. Nor would holding the winch while putting the bolts in.
Well sounds like I need to order a pizza and grab some beers. Going to be a long night :LOL:
I was able to do the install short of 4 hours solo. Most of the time was spent goofing around with which way to run power wires around everything else by the air filter. The control box mounting is also interesting with the stiff power cables coming out, they are about a 1/4" too long.
I saw the picture. To me it didn't look like a "1/4 hole" worth of material was removed from the nut to make it fit. They are about that much off when the wrong side goes in first.
In my opinion I wouldn't remove material from a fastener if that was the issue and I would instead remove material from the casting that was off. It was most likely powder coat build up in the corner of the pocket which could come off pretty easily.
Just my two cents.
Just my two cents.
Finished up the install of my winch last night. Spread it out over a few days.
I ran into the same scenario where the 2 winch nuts on the driver side go in fine but the passenger side would not slide in far enough to line up with the hole for the bolt. To get the passenger side in without removing any material from the winch or the nuts; I just took a small punch and tapped them into the winch until they lined up with the hole and a bolt would thread on. Seemed to solve the issue for me, not sure how much variation there is winch to winch but maybe this will work for others as well.
Another thing to note. Maybe not so relevant to this thread but I was able to get the winch mounted and up high enough to still use the factory trim around the entire fairlead plate and enough clearance for the free spool lever. Also, with the bumper as high as it will go as well.
To do this, when I installed the LH and RH end mounting brackets, I noticed there is a ton of play up and down. If you push these up as high as they can go while tightening them down, this then gets the winch up as high as it’ll possibly go. I used the same method when installing the winch, pushed it up while tightening the bolts. So far everything clears and looks great too.
Great to hear you got it and glad I'm not the only one with the problem. I admittedly did not try forcing them in. Maybe it was just paint buildup at the end of the slot.
I did the same regarding making everything high. I REALLY did not want to grind on my bumper. We pushed up on all the brackets and the winch while tightening the bolts and my free spool lever clears the bumper fine.
I just called Warn to let them know about the problem and emailed them pictures of the nuts I ground. They were thankful for the information.
Oh boy! Mine is going in tomorrow for the winch install. I will be watching this area of the install specifically....... Good stuff to know.
Reply from Warn says they've seen this before and it was paint buildup. They're going to specifically watch for it now. So if you want to tap the nut in and/or find a way to dig the paint out of the corner, that may be easier than grinding the nuts.
I hate "grinding the nuts"!!!!!!
My install today was perfect. Have a thread posted with pictures.
Is it the beans or the frank?
Sounds far worse than just a zipper incident!
