the only real solution is to swap headlights, I think Morimoto and Alpha recently debut a product that is out or coming out this year where you hold the flash to pass for x seconds and if the temp is below a threshold it turns on the heating elements inside the headlamp assembly. No factory option exists.Did you ever find a solution to the headlights icing up? I drive alot across Canada and the upper midwest, and headlights icing up has become a considerable issue. On Friday I was in a snowstorm in WI, and thought I had burned up a headlight but no it was just iced up (just over 1 inch thick of ice). This is a huge safety issue.
