You can weld the adapter in place if it rattles and it really bothers you that much. I welded the 2.5" to 2" adapter into my 2015 after losing the adapter 3 times. If you're ever nearby Lake Tahoe, stop by and I'll do it for you.
Good idea. Couple of small tacks and she'll be good to go.You can weld the adapter in place if it rattles and it really bothers you that much. I welded the 2.5" to 2" adapter into my 2015 after losing the adapter 3 times. If you're ever nearby Lake Tahoe, stop by and I'll do it for you.
Here is the old one and the new one. I have several trailers with different heights so I need some adjustmentsWhat did you buy? Most of the 3” options I’ve found are way over capacity
Unfortunately those won’t work with a WDH.Here is the old one and the new one. I have several trailers with different heights so I need some adjustments
View attachment 36160View attachment 36161
I only have one trailer that needs WDH.Unfortunately those won’t work with a WDH.
Is this going be another adapter or their own WDH design? I'm running their 3 inch with a 6 inch drop and adapter for the Equalizer now. I know a couple people on here had problems with bent pins with other setups and Bullet Proof removed it from their site. Curious if they'll let me trade it in for peace of mind. However, I haven't had any problems with the adapter. Knock on wood.Bulletproof might be releasing one soon. They'll probably have a quality, although it will be an expensive build.
Edit: just heard from them they expect to release it first quarter of 2022.
What do you think about have a good welder weld in the adaptor and then paint it up ( make sure the holes are nice and lined up and square). You would be done, no rattles and no messing around lining up the pin.Unfortunately those won’t work with a WDH.
My though is you already have the receiver hitch, why purchase another? Plus its factory installed I would hope the factory hitch is very good.
If you are running 1,300 to 1,500 lbs. of tongue weight you need at least a 2.5" - most 2" are only rated to 1,000 lbs. of tongue weight and 10,000 lbs. total - where at 2.5" will be 1,500 lbs. of tongue weight and 15,000 lbs. total.Who makes one other than Andersen? The RV dealer said they’ve had a lot of problems with them and highly recommended anything but them. I need one for a 10k gross weight trailer with a tongue weight of 1300-1500lb.
I like to error on the side of caution and safety when towing - excess capacity is never a bad thing. Weigh safe offers a flexible system. You can get their 2.5" shank and WD hitch set up, which is not cheap, but is really nice and works great. Then get one of their drop on ball holders, when you don't need WD hitch.
WD Hitch on 2.5" draw bar - locking pin holds it on. When don't need WD - swap out with regular hitch slider - see below
Use same 2.5" draw bar - get 180 slider - ball combo and pin and just slide it on draw bar for all other towing!
If your asking if you have to take bed payload into account when calculating spring bar capacity, the answer is yes if the payload is behind the rear axle.Can someone tell me if the bed payload will increase tongue weight?
That’s what you did and it works greatI would use the factory 3 inch with 2 reducers, you will have no trouble at all
I’m in same boat as OP @NickinColorado
I hate the 3” receiver. No one has a hitch with a 3” shank! And no one has a 3 to 2 reducer, either. Go figger.
I use a Blue Ox Sway Pro with a 2” shank. I have two reducers that my buddy welded together for me. The whole thing feels Rube Goldberg to me.
Here is the 3" to 2" receiver adapter I bought for mine:
Husky 3" to 2"
Here is the 3" B&W Tow and Stow hitch:
3" B&W Tow and Stow
For WDH, I use a Blue Ox SwayPro with a 2.5" shank with a 7" drop and the 2.5" receiver adapter from Ford.
