It's most likely normal operation imoAnother owner that is currently experiencing this same downshift jerk, with Tow/Hual & Exhaust Brake ON 3-2 gears.
Drove in buddies '19 Cummins (6 speed-auto) and he's behaves the same with the same functions on.
The question is: is this normal learning pattern and leave it or should we all be clearing the TCM?
Tow/Haul mode also activates the engine brake, even though there's no dash indication.Tow / Haul mode locks the converter early and keeps it locked along with reving slightly higher in each gear before shifting. It also down shifts earlier for higher RPM in the lower gear, with or without a locked converter depending on gear.
EB *should* simply add more compression braking to the engine. No trans shift changes.
The EB was on the other day with the family all loaded up to go out of town in the ran. (I like using the EB without towing in the rain), 2 miles from the house (cold trans) it down shifted in regular drive mode so hard coming to a stop the tires slipped and everybody in the truck got jerked hard.
Engineers should not have these down shifting from 3rd to 2nd or 1st into a LOCKED converter in Tow/haul mode nor Regular drive mode, which is what is going on. For crawl mode and in 4L, sure, but not in normal drive nor tow haul.
Trans Learning is trying to soften the clutch engagement on the down shift, when the true fix would be downshifting into a fully unlocked converter.
You are correct that T/H mode uses engine braking, but the Exhaust Brake feature is only activated with the E/B button.Tow/Haul mode also activates the engine brake, even though there's no dash indication.
In my testing, I experienced the harsh downshift (never a harsh upshift) in T/H both while towing, and without. I then tried normal drive mode with EB engaged and experienced the exact same issue. In any mode other than T/H without EB engaged, there was no harsh downshifting.
NoIs this what you guys are experiencing? I can replicate it consistently on a hill near my place.
I thought engine braking and exhaust braking were the same thing?You are correct that T/H mode uses engine braking, but the Exhaust Brake feature is only activated with the E/B button.
I feel it helps keep the valve from sticking ( doubt there is any science to this).
Not exactly. The manual is confusing to say the least.I thought engine braking and exhaust braking were the same thing?
Edit: the manual uses the terms engine brake and exhaust brake interchangeably, so my assumption is that they’re the same thing on our trucks.
Thanks, great info.Not exactly. The manual is confusing to say the least.
"Exhaust brakes retard power in a diesel engine, but in a different way than engine brakes. Engine brakes release compressed air through an exhaust valve, but exhaust brakes hold the compression in the engine and slow the crankshaft's rotation, which reduces vehicle speed."
https://auto.howstuffworks.com/auto-parts/brakes/brake-types/engine-brakes2.htm
Our trucks do not have a real engine brake, so I am not sure why the Ford Manual refers to it in that manner.
Here is a good discussion on it from another forum:
Tow Haul Mode or Exhaust Brake or Both
I use T/H and EB in auto when towing my 16K lb camper and there is definitely a difference with the EB on/auto vs EB off.
This is what I experience. Reg drive mode, EB on, slowly coming to a stop. Happened every time I got it to go 3-2-1 but only if I was going faster (40ish & above). Won't do it at slower speeds, say in a parking lot or through the neighborhood.
Are you on the brakes when this happens or just coasting with the EB slowing you down?
In my 2021 at least (haven't had a reason to use the EB on my 2022 much yet), if I had the EB on and started applying the brakes at low speed, in low gears, unloaded, the EB would dis-engage.
If I actually had some weight on it would keep the EB activated longer. The truck knows how much load is on the driveline and makes adjustments accordingly.
Dr Speed......yes! Mine is doing that x5...it almost feels like it's going to run away as it surges hard in and out of the gears and gains speed. I have to go hard brakes to get it to settle back down. No trailer/no load and happens both in Auto and normal engine brake not in tow/haul.Is this what you guys are experiencing? I can replicate it consistently on a hill near my place.
